Results 1 to 21 of 21
Like Tree2Likes
  • 1 Post By acarmody
  • 1 Post By monaro327
Thread: Recommend running a trans cooler?
    undersuspicion is offline Now That's How We Roll!
    Vy SV8 Series 2
    Aug 2010
    Default Recommend running a trans cooler?
    Have an auto vy ls1, looking at getting an exhaust, otr and cam package for it. Would you guys recommend running a trans cooler with it? Also looking to upgrade hi stall and go for diff gears. Spoken to some shops but none of them have mentioned unless i have asked for a price.
    Is it recommended if upgrading other bits and pieces and making more power to put in a trans cooler/upgrade trans cooler?
    don't take this wrong or anything but ARE YOU ####ED IN THE HEAD????
    Reaper
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The main reason for fitting a trans cooler is if you do a lot of towing. If not, I wouldn't worry about it.
    Visit my Facebook page
    Vy SV8 Series 2
    Aug 2010
    Cheers Abba, car doesnt even have a tow ball lol. Had heard that if you change hi stall you should upgrade/install a trans cooler?
    Reaper
    acarmody is online now Donati..Whoa Green
    VX Berlina
    Apr 2007
    PWR make some nice trans coolers for a decent price. Any transmission place would be able to fix you up for cheap.
    Ronald Reagan (1986)
    Vy SV8 Series 2
    Aug 2010
    if i wasnt towing anything, would i see any benefit from running one? Looking to do a few burnouts, wouldnt be a daily thing, maybe once a month. Obviously putting strain on the transmission would i benefit from running one then?
    Reaper
    VX Berlina
    Apr 2007
    The higher the stall speed of the converter the more heat it will make, and since heat is the #2 killer of transmissions (behind stupidity) it would certainly be helpful.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Running a trans cooler is always a good idea, and will extend the life of your trans regardless of what you're doing.
    Whether it justifies the purchase price or not is another story.
    Vy SV8 Series 2
    Aug 2010
    no worries, got quoted $400 fitted. Have the budget for it so i may as well get one installed. Thanks for the input guys, Was just curious as to if it was worth the money or not.
    Reaper
    VX Berlina
    Apr 2007
    Holy shit $400? I hope that involves an oil change, than its about right.
    Just get the thickest one you can, also make sure they don't bypass the radiator trans cooler.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    VY SS UTE
    Jun 2009
    Mandurah, WA
    Quote Originally Posted by acarmody View Post
    just wondering why you wouldnt bypass the radiator transcooler?
    Vy SV8 Series 2
    Aug 2010
    i dont know a whole lot about them. But i know active automotive here in WA has quoted $400 fitted, not sure what brand they use or if it includes an oil change.
    Reaper
    VX Berlina
    Apr 2007
    Quote Originally Posted by nathanVS View Post
    they coolers themselves can cost up to 400! depends how good you want to go
    I know, I've seen some big ones in some performance shops. Saw one once that I mistook for a smallish intercooler, this thing was huge.
    VX Berlina
    Apr 2007
    Quote Originally Posted by W45H1NGT0N View Post
    If you bypass the tranny cooler your only getting a slight upgrade from what it was. If you leave it in place you get more than double the cooling.
  15. #15
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Yes true, but if you bypass it then if the radiator tanks split you won't get coolant mixing with trans fluid...... but that's unlikely unless your radiator is 400 years old
    Although it happened to my first car which was a volvo lol.
  16. #16
    Vy SV8 Series 2
    Aug 2010
    im thinking as a performance shop is installing it they should know to either bypass or not bypass the tranny cooler?
    Reaper
  17. #17
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I have always bypassed the radiator when fitting a trans cooler so the heat doesn't transfer from one to the other. If you are putting load on the transmission and it heats the fluid up, you won't be transferring that heat to the radiator and adding another heat source for it to try and cool down. The radiator is then left to only regulate the engine temperature.
    If you wanted to go one step further, fit a manual radiator to remove the coolant pipes from the tanks so there is more room for coolant, only a small amount, but it can only help.
  18. #18
    Vy SV8 Series 2
    Aug 2010
    cheers abba, will probably ask them to bypass the radiator. Although not sure if they would do that anyway.
    Reaper
  19. #19
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Good point abba!!!!!! Or if you really wanted to just keep your auto radiator and plumb your power steering in through the leftover oil cooling bit.
  20. #20
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Depends on the size of the cooler whether you run it through the radiator.
  21. #21
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    Don't by pass the radiator, most people think the fluid runs through the rad for cooling not completely true. it's main function is to actually heat the fluid.
    if you by-pass the radiator and just fit a big cooler, in winter your gearbox might not ever reach proper operating temperature. the idea is the coolant from the engine transfers some heat into the fluid passing through the coil in the rad and warms it up to help the gearbox reach operating temp faster.
  1. Auto Trans cooler or oil cooler?
    By Dr.304 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-04-2011, 10:01 PM
  2. should i get a trans cooler for my vp
    By sawychri06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-08-2010, 11:13 PM
  3. running cooler
    By peeingeye in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-11-2009, 06:23 PM
  4. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  5. V8 trans cooler on a V6
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2007, 08:20 PM
