Results 1 to 3 of 3
Thread: Ignition problems?
    VY s ute
    Apr 2011
    Default Ignition problems?
    Hey All,
    Just wondering if anyone has come across this problem before or could point me in another direction.
    I have a VY S ute auto. The vehicle will never fail to start; however, it often takes 2-3 turns of the key to get it to kick over. Often when it starts it will cough and splutter for a moment then fall into the normal idle rev range. This is not so prevalent in cold weather (but still happens) but when the vehicle is warm or in warm weather it becomes a lot worse.
    I have had the vehicle in the Holden workshop and apparently it doesn't come back with any fault codes. I have had the injectors overhauled, replaced the HT leads, coil packs, sender unit, spark plugs, fuel pressure regulator and fuel lines cleaned out.
    The only thing i have not yet done is replace the crank angle sensor??????
    Any ideas?????
    Cheers.....
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    Worse when its hot,, could possibly be the CAS (crank angle sensor).. Mine had similar symptoms when it was failing, it got to the point were i had to pour water onto the CAS to help it cool down quicker so the car would start again...
    Signature Goes Here
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    You need to clean the Idle speed solenoid on the throttle body..
    Get yourself a can of throttle body cleaner remove the ISS squirt in the hole and the tip of the solenoid and re assemble..
    If the problem is still there replace the IIS..
    There on E-bay cheap..
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
  1. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  2. Ignition Problems!!!!!!!!!!!!!!
    By VRc0mmy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2006, 05:14 PM
  3. VP ignition problems!!
    By JayDBH in forum Electrical Wiring / Questions
    Last Post: 04-03-2005, 05:45 AM
  4. Vr Ii Ignition Problems
    By joem in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-03-2004, 12:47 PM
