Results 1 to 20 of 20
Thread: horn just starts going off while driving
    vy berlina 5.7
    Mar 2010
    QLD
    Default horn just starts going off while driving
    gday all
    I have just bought a vy berlin with the 5.7 gen 3
    the last few days ill just be driving along and the horn just starts going off why would it do this i cant find anything in the manual
    any help would be loved thanks
    aussie
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    When it goes off can you stop it by manipulating the horn pad on the steering wheel?
    Does the horn work normally apart from your issue?
    Silver Certified.
    vy berlina 5.7
    Mar 2010
    QLD
    yer mate i give it a tap and it stopes sometimes it startes to go again sometimes it doesn't
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    sounds like the harness under the airbag is shorting out,
    take it to a workshop and get airbag taken off and the horn "plate" and "harness" checked good luck~!
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    yes had this on a VY where I worked - they changed the airbag horn pad and it stoped. It went off most of the time in the afternoon when the sun heated up the car - it never happened while parked in the shed.
    and 3 Dangerous non ABS VN's
    vy berlina 5.7
    Mar 2010
    QLD
    is it much of a job and where is the horn ill have to disconect it till i can get it in monday
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    look up under your bumper right side? youll see it or you can pull the fuse in the fuse box
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    If I recall correctly, there was an issue with a metalised barcode strip fixed to the back of the airbag which could become partially detached in warm weather and cause a short, activating the horns. The cure was to remove the airbag and pull the tag off completely, then refit the airbag. I'm sure there are threads on here somewhere about this problem. It's certainly worth looking at this as a first option before paying for a new airbag or wiring.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    PROBLEM DESCRIPTION
    Some customers may complain that their vehicle’s
    horn intermittently sounds on its own.
    Investigation of these cases reveals that a metallic
    backed barcode label fixed to the steering wheel
    directly below the horn bar contact (which is located
    on the underside of the airbag) may curl up and earth
    the horn bar contact which causes the horn to sound.
    This condition may be more common with increased
    cabin temperatures.
    PRODUCTION RECTIFICATION
    Steering wheels with relocated barcode labels were
    fitted to vehicles from:
    ISOVIN: Build Date:
    6G1YK43A23L968463 29/1/03
    SERVICE RECTIFICATION
    1. Remove the air bag as per the procedure in PV
    SIP VY / Electrical System / Section 12M
    Occupant Protection System / 2. Service
    Operations / 2.3 Steering Wheel Inflatable
    Restraint Module Assembly.
    2. Inspect the steering wheel hub for a label as
    shown in Figure 1.
    3. Remove the label highlighted in Figure 1.
    4. Reinstall the air bag as per the SIP procedure.
    Silver Certified.
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by RiCeY View Post
    PROBLEM DESCRIPTION
    cabin temperatures.
    ISOVIN: Build Date:
    shown in Figure 1.
    And that, friends, is the technical way of saying exactly the same thing I did, but taking about twice as long to say it.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    It amuses me that you would even begin to consider that your intelligence is higher than mine.
    Those that arent intellectually challenged like yourself would realise that I simply cut and pasted an official Holden techline to reinforce what you posted.
    But hey dont let me stop you from trying to boost your own ego as youre clearly feeling a little insecure if you need to use the lowest form of wit also known as sarcasm.
    Silver Certified.
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Mate, I think you have totally misinterpreted my post. If it offended you or annoyed you, it wasn't meant to. And it was meant to be humorous, not clever or sarcastic. There are quite enough sarcastic people on this forum - I don't need to join them.
    And I'm way too old to bother trying to boost my ego.
  15. #15
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by Calaber View Post
    Yes I did misinterpret it and therefore retract my offensive reply and apologise.
    Silver Certified.
  16. #16
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    All cool mate. Looking over my post, it can be seen to come across as smarty-farty. I was really referring to the long winded way the technical report addressed the problem, certainly not shooting at you.
    I wonder if our advice fixed his problem.
  17. #17
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Well, I'm glad you two sorted out your little "issue"!!! LOL I was just glad to see that the problem was rectified from 29/1/03. So mine being a 10/03 model shouldn't have this problem.
  18. #18
    vy berlina 5.7
    Mar 2010
    QLD
    thanks all it was that sticker
    the auto elec wouldnt of found it i didnt tell him he said
    he is now a member of this site
  19. #19
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Thanks for the feedback mate. Nice to know that Ricey and I were on the right track for you.
  20. #20
    VY S
    Apr 2010
    Wellington
    Good info guys. I had the same problem and fixed it with info from here. Took 15 mins and cost nothing. If I had taken it to my dealer I'm sure they would have charged heaps.
  1. Help car only starts when it wants too
    By kevinb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-01-2011, 05:06 AM
  2. Replies: 33
    Last Post: 09-11-2010, 12:21 PM
  3. What starts with...
    By bazcom in forum Jokes/Humour
    Last Post: 06-07-2008, 08:51 AM
  4. Replies: 3
    Last Post: 03-02-2007, 09:51 PM
  5. VP only starts on second try
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-10-2006, 11:51 PM
