Hey guys, quick question,
the two nozzles that fire the water onto the windscreen to wash it in my VY exec wagon are buggered. they spray water everywhere except where i want it, and havent been able to fix it by cleaning them out with a pin.
has anyone replaced them before? whats involved with the removal of the old ones and replacment?
also, i was able to find nozzles for the model vn to vx but assume these wouldnt work for the VY?
any help would be greatly appreciated, and thankyou in advance!
If you have access to an air compressor, blow a small amount of air into the water line (just pop it off from the reservior). You could even blow air from your mouth but you may get a little dizzyThis should unblock them. With the pin you have, you can also adjust the aim of the jets. Just stick the pin in and move the nossle and then test where the water sprays. Keep doing it till they spray where you want.
