Results 1 to 4 of 4
Thread: Removing complete vy auto shifter
    VYSV8 1957 Chev
    Apr 2011
    Default Removing complete vy auto shifter
    Has any one done this??
    Took centre consol out and it looks as if it is bolted from underneath the car?
    I was going to jack it up and have a look but I had a new front screen installed today and didnt want to risk stuffing up the seal.
    The reason im removing this is the top of the shifter has been snapped off!
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    As in the plastic button/handle, or the entire metal shifter shaft going into the gearbox? If the latter, it's probably a gearbox out job... If just some part of the plastic handle, follow this (but you'd have to do this anyway to get the gearbox out):
    First make sure your handbrake is on and holding since you will have to move the shifter out of Park at some stage.
    Remove the center console trim piece:
    -remove rubber tray under the radio, it just pulls out
    -remove the philips screw on the right side of the tray area
    -remove center console trim piece, 6 clips as shown below, unplug window switches from the bottom, put it aside. The first time you take this out requires a fair bit of force and feels like you are going to break something.
    I disengage the two clips at the rear by prying it up with a flat head screw driver wrapped in tape, then i work my way to the front prying with my fingers and it gets the rest of the clips.
    Now by this stage it looks like you could unclip the shifter surround from the shifter assembly, but you can't unless you're an octopus with a vast array of jewelers screw drivers, and the shifter assembly won't come out because it is trapped by the frame of the center console. It's easier to just remove the entire lower console to get it out.
    Remove the console:
    -unclip the drivers side lower center console trim - one clip - pull down on it near the handbrake. You can either leave it like that, or remove it entirely by opening the fusebox cover and removing an additional two philips screws. This makes reinstallation a little easier.
    -remove the philips screw from the rear of passenger side lower center console trim - slide the passenger seat all the way back, remove philips screw (slightly obscured by seat). Can remove entirely by dropping the glovebox and removing two additional philips screws.
    -pull out rubber liner inside the center console storage bin (takes some force), remove the two nuts underneath.
    -remove 4 philips screws securing shifter surround to center console
    -remove philips screws securing lower center to upper center console.
    -unplug cigarette lighter socket power cable (white plug near window switches area)
    -lift out the entire lower center console (pull up from rear and lift out).
    Hopefully you should now have this:
    Then you can remove the shifter assembly:
    -remove hex screw from back of gear knob
    -unplug electrical connector
    -lift out surround and shifter assembly
    Do whatever you have to do with the shifter handle, reinstall everything in the reverse order.
    VYSV8 1957 Chev
    Apr 2011
    Default VY shifter removal
    Thanks TMM, I have got that far but I need to know how the complete shifter assembly comes out as the shifter is actually broken
    Cheers.
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    Sorry to bump but anyone have this for the auto? My shifter may be on the wrong way to the linkage
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
  1. Removing Shifter from Getrag Gearbox
    By antelopeslr5000 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2010, 08:12 PM
  2. [NSW] For sale complete b&m mega shifter setup ( vn - vs v6/v8 )
    By STOKED in forum Parts And Other Items For Sale
    Last Post: 28-01-2009, 10:58 AM
  3. Help with removing auto shifter handle on VS
    By Shaundy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-01-2009, 01:23 PM
  4. F/S T400 complete conversion vb-vp, 2800 stall B&M shifter
    By Devils_VK in forum Parts And Other Items For Sale
    Last Post: 10-12-2007, 04:04 PM
