Results 1 to 5 of 5
Thread: vy gts hydra trac diff
    03 5.7 vy ss
    Mar 2008
    ipswich qld
    Default vy gts hydra trac diff
    hi all, can someone tell me if an original 3.45 vy gts hydra trac diff
    is a lsd, buying one in 2 weeks just want to make sure, cheers
    03 5.7 vy ss
    Mar 2008
    ipswich qld
    VY2 S, VS exec and VG ute
    Mar 2011
    east gippsland
    i think they are just do it in a different way. Exey to fix, do some research on how the hydratrac diff works. Depending on the amount your paying for it.....might be just as cheap so source a ss lsd and change gears to suit your needs
    VX Senator 300
    Oct 2005
    The 'gul, Vic.
    They are Limited-slip and work with a viscous fluid, which thickens when load is applied. i do not know the physics, but the viscous fluid takes the place of the locking clutches, to provide drive to both axles.
    A VY Hydra-trak will require different stub axles to the mechanical differentials, or it will not fit up correctly. So, make sure you get the diff AND stub axles, or you'd have to source some through Holden / HSV - ouch!!!
    A Y-GTS diff with that ratio will have come from an auto.
    cheers
    Senator 300 - the CLASSY C4B!
    LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
    03 5.7 vy ss
    Mar 2008
    ipswich qld
    thanks for the info macca33, what do you mean by the stub axels, mine is an auto to so that part is ok
  1. How does abs/trac work
    By madsav in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-05-2010, 04:39 PM
  2. Trac off and abs light on???
    By 11gothevt11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2010, 04:43 PM
  3. Help Low trac light comes on!!!!!
    By scbh81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2008, 10:46 PM
  4. Ex-police no trac
    By SSbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2008, 10:42 AM
  5. Where can i get info on the hydra trek diff
    By shanhsv in forum V8 Development and Modification
    Last Post: 02-10-2006, 06:49 PM
