Results 1 to 20 of 20
Like Tree4Likes
  • 4 Post By one_and_only2004
Thread: Fog Lights hook up to parkers?
    VY Storm
    May 2011
    Queensland
    Default Fog Lights hook up to parkers?
    Ive got a v6 vy series 2.. which means theres no wiring for the fog lights, was just wondering to do it an easy way can i just get some and hook them up to my parkers?
    VY SS
    Jun 2006
    Albany
    you can if you use a relay but it will be illegal unless you wire it through a switch aswell
    VY Storm
    May 2011
    Queensland
    yeah, im not sure, it seems like an annoying job... im thinking bout just heading down to autobarn and getting them to install it all, just not sure how much it would cost?
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Don't go hooking them up to your parkers as it's illegal to have them on when there isn't any fog.
    There's far too many douches on the road doing it as it is.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    your ute being a storm should have the wiring there?
    should just need to pull the dash facia off and untape the connector on the loom, plug in the switch and put a relay in the fog light spot in the fuse box
    VY Storm
    May 2011
    Queensland
    Boonz's Avatar
    Jul 2005
    why does being a series 2 mean it doesnt have the wiring there?
    from what i remember, all models from VT onwards have the wiring there from factory (except executive)
    VY Storm
    May 2011
    Queensland
    yeah, but ive been told that they didnt put the wiring there for the series 2 vy's but is for the series 1's, which is quite rediculas
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    03 VY V6 S2
    Oct 2005
    Series 2 wont have the wires.
    All you need is a relay, some wire and a switch. Also some black tape and crimp lugs.
    Actually if you get a switch with a high enough amp rating you dont even need a relay...
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Crimp lugs are for noobs - just saying...
    A relay can ensure more 'juice' gets to the lights as well as minimising the risk of switch/wiring meltdown.
    Also, be sure to have a fuse inline.
    You can get foglight wiring kits at supercheap etc.
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    VY S Series 2
    May 2010
    just grab a new switch from holden and a relay... i wired them up myself and it only took about 3 hours of actual work... spent the other 5 going to burson's cause i broke connectors and cause i wired them up wrong the first time
    its actually not that hard once you get your head around what you have to do
    VY2 S, VS exec and VG ute
    Mar 2011
    east gippsland
    I did this a year or so ago, wanted it to look as factory as possible. Bought some SS foggies (clones) off ebay for $120, factory fog light switch $60 and some genuine foglight connector $16. Got a relay/inline fuse all built into one unit. Few meters of wire and followed this guide.
    Cobra30.com - VY Commodore/Crewman Fog Lights Installation
    All works as per factory except I dont get the green light in the cluster to say there on. But turnt on and off with the other lights and work correctly off the switch.
    Think its definatly worth it, they look heaps better in the S bumper than the black inserts. As for light output....meh, dont think they offer alot more than the standard headlights
    VY SS
    Jun 2006
    Albany
    Quote Originally Posted by Fletch_QLD View Post
    crimp lugs are for noobs ay? do you solder the wiring straight to the relay terminals then lol
  15. #15
    Jun 2005
    Brisbane Bayside
    Quote Originally Posted by axemurderer101 View Post
    I stand corrected - and withdraw my earlier comment. In a moment of haste I replied thinking of those piggyback crimp connectors that are used to crimp onto and hook into existing wiring. Clearly crimp lugs is the same as crimp terminals etc, and have a place in this situation.
    I stand hat in hand and reflect that clearly, I am a noob.
    cheers.
  16. #16
    VY SS
    Jun 2006
    Albany
    lol its all good, if you are talking about scotch locks then i hate them with a passion too. ive had to rewire plenty of trailer plugs thanks to those stupid connectors
  17. #17
    Jun 2005
    Brisbane Bayside
    Ah - scotch locks. Never knew what they were called. Yeh - endemic in dodgy trailer installs, but also common in aftermarket foglight/driving light installs.
    off topic - omg you still use ICQ ?
  18. #18
    VY SS
    Jun 2006
    Albany
  19. #19
    Jun 2005
    Brisbane Bayside
    Under your name - you have icon - like a green flower.
    ICQ is like from before msn. But I guess you don't still use it (or ever did) so nvm
  20. #20
    03 VY V6 S2
    Oct 2005
    Quote Originally Posted by 1_johnboy View Post
    Pin 4 on the cluster is for the foglight led. If you apply 12v it comes on.
  1. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  2. Keyless entry, hook up lights?
    By anarklov3r in forum Electrical Wiring / Questions
    Last Post: 11-01-2009, 08:49 PM
  3. Keyless entry, hook up lights?
    By anarklov3r in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2009, 05:52 PM
  4. brake lights on with parkers
    By igobrm in forum Electrical Wiring / Questions
    Last Post: 13-04-2008, 04:03 AM
  5. No Parkers, Speed Alert, dash lights or shifter lights.. Help..??
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 10:36 AM
