Results 1 to 10 of 10
Thread: breaks
    vy berlina 5.7
    Mar 2010
    QLD
    Default breaks
    morning all
    my breaks on my vy started to make some noise
    had it checked and the bloke said it was just break noise and will not go away
    the pads are only 2 months old
    is there anything i can do??
    Thanks
    VY SS
    May 2011
    Auckland
    Did you have them fitted? If so take it back to whoever did it and tell them to fix it. If you bought them and did it yourself go talk to the retailer but I don't know how far you'll get, they'll probably say it was an installation fault
    vy berlina 5.7
    Mar 2010
    QLD
    they were done at a shop but the shop is 6 hours away
    there bendex not cheep ones
    would changing them around help
    or do i just buy a new set of pads
    VY SS
    May 2011
    Auckland
    vy berlina 5.7
    Mar 2010
    QLD
    VY SS
    May 2011
    Auckland
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    What sort of noise are they making? Is it a scraping sound or more like a squeal? Were the brakes noisy when you first picked up the car?
    A scraping sound could be a small stone caught in a pad. A squealing sound is possibly caused by "pad glaze", which happens when you have really hard pads. They need lots of heat to work effectively and can be too hard for street use. They develop a polished surface, or glaze, which then leads to less effective brakes and squealing. Glazing can also be caused by a seized caliper, which leaves at least one pad running firmly against the rotating disc at all times. This polishes the surface of the disc and causes glazing.
    Either job means take all the pads off and inspect them.
    vy berlina 5.7
    Mar 2010
    QLD
    its a squealing ill do it today will i have to get them machined or can i do something elce
    they are hard pads
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    does it squeal under light breaking/hard breaking?
    You could possibly try to get her up to 100km and stand on the brakes do this a few times always helps me with brake squeal
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Quote Originally Posted by aussietim View Post
    they are hard pads
    You can break the glaze by taking the pads out and rubbing them on a nice flat smooth concrete floor for a few seconds. Don't do it too long or you'll just wear the pads down. They will leave a dust mark on the concrete that will sweep away easily. You might find you have to do this every now and then because unless your driving is hard enough for the pads to reach their optimum working temperature, they will glaze over again.
  1. need your advice on breaks for my car
    By anonymousmoose in forum General
    Last Post: 30-07-2010, 01:12 PM
  2. vs v8/v6 breaks?
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-02-2010, 06:50 PM
  3. When do your breaks need to be upgraded?
    By Weapon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2009, 06:29 PM
  4. Vg ute squeaky breaks
    By johnvncommy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2009, 10:17 AM
