im sure its been asked a million time but i just want a straight up answer..
if i buy genuine fog lights and headlight switch with fog light can i just plug them straight in and thats it?
i have a vy s pak btw..
its not that simple... series one has the wiring already series 2 doesnt... youll need a switch and relay from holden and try and find a copy set of foglights on ebay cause they are about $400 for a geniune set from holden
if its a series 2 and you dont have the wiring then its not too hard to wire up the only hard bit is getting the wire into the back of the new switch
pretty sure its a series 1 and i checked and fairly sure the plugs are there. what switch from holden will i need? is that just the headlight switch with the fog light part?
yes you need
the fog light/headlight combo switch assembly
the relay that goes in engine bay fuse box
the foglights... should be 2 waterproof plugs cable tied to the chassis roughly where the foggies are
my cars to low to get under and have a look but i could feel some kind of plug just behind where the fog light sits. so ill get all the stuff i need and hook it up n see wat happens. just wondering how i go about getting the black cone things out n putting the lights in.. do i need to take the bar off?
The black cone is fixed by two clips/tabs... You just push these in whilst pushing it out and it should come out no dramas at all![]()
too easywat bout the fog lights? do they have the same tab or do you use the 3 screws at the back?
Sorry for the late reply mate, but yea the fog lights are fixed by three screws from memory![]()
put them in on friday and they worked first goso happy! ill probs add pics soon
lucky you lol i had to go through the hastle of wiring mine up when i put them input them in on friday and they worked first go so happy! ill probs add pics soon
yea i would have hated doing that!
heres the link to my car
Brayden's S/C VY ll
