Results 1 to 8 of 8
Like Tree2Likes
  • 1 Post By axemurderer101
  • 1 Post By db_notso
Thread: Car Stereo Problem
    VYII Executive 3.8
    Mar 2011
    The Oaks, NSW
    Default Car Stereo Problem
    The other day i purchased this head unit from JB Hifi the other day, wire it all up using this wiring harness. (Just a note, it's not the head unit, works fine in a mates car)
    Everything works great but i dont think the constant 12v is working, everything is wired up perfectly but the head unit will not remember my settings, once the key it out and everything is off, the head unit turns off aswell. Rather than running a wire from the constant 12v of the headunit back to the battery, is there something im missing here?
    VY SS
    Jun 2006
    Albany
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    well that plug is a HALF ISO plug
    so you had to wire it to your cars instrument harness? then plug stereo into it...
    or you wired it into stereo and plugged cars harness into it...
    i dont remember which way around with a half plug...
    but regardless either way you have to check the same things...
    basically ISO is a type of plug that changes the cars standard wiring to the stereo manufactures standard layout
    there is one wire that should "never" lose power when the ignition is off
    and one that gets power when the ignition is on but not when its off
    so you need a multimeter and stereo out
    and make sure that one wire (prob red) at the iso plug that plugs into your stereo wiring
    has 12 volts when ignition on but not when ignition off
    and one other wire "memory wire" should have 12 volts ignition on OR off
    alot of people get the two the wrong way around
    if only one has power ign on but not off and no other wires has power at all
    then check all your fuses under the rh dash one is probably blown...
    VYII Executive 3.8
    Mar 2011
    The Oaks, NSW
    You guys are bloody legends, swapped the yellow and the red and now it's remembering all my settings!
    Another question though, this head unit has a Steering Wheel Remote Wire, can i hook this up to my steering wheel controls somehow?
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Quote Originally Posted by Neodude112320 View Post
    You need to get an interface - like this one you get the one to suit your head unit and it's all good $80 inc postage. Pretty easy to set up.
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    VYII Executive 3.8
    Mar 2011
    The Oaks, NSW
    Couldnt i just plug the Brown wire to the remote wire and ground out the black wire?
    Jun 2005
    Brisbane Bayside
    Yeh mate, do that.
    If you want the steering wheel controls to actually do anything, you need to get an interface to suit your headunit.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    yes you need an interace as it changes steering button commands to stereo commands...
  1. Stereo Problem.
    By Deneo in forum Electrical Wiring / Questions
    Last Post: 18-03-2010, 04:51 PM
  2. Stereo Problem!!!
    By OBR1EN in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-05-2009, 10:38 AM
  3. vz stereo problem
    By STURTZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-12-2008, 12:24 PM
  4. Stereo Problem
    By Mossman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-09-2006, 04:25 PM
  5. stereo problem please help?????
    By daveatron in forum Car Audio
    Last Post: 22-07-2005, 12:56 PM
