Results 1 to 7 of 7
Thread: Idling issues after Cold Air Induction VY Calias S/C with LPG
    VY S/C Calais
    Apr 2011
    Merriwa WA
    Default Idling issues after Cold Air Induction VY Calias S/C with LPG
    Hi, I have had some issues with my S/Charged VY Calais after I introduced a do it myself Cold Air Induction. I have provided 2 of 4" tubes from the standard Type S airbox. This has done 3 things.
    1. Given me more economy. ie. I was getting 500kms (country) from a 74lt tank of LPG, now 600kms per tank.
    2. Makes the car run much cooler than before.
    3. Struggles to find idle speed when starting from cold. For the first 30 sec after cranking, RPM drops to around 500RPM (or stops dead) and then gets the idea and stabilises to around 900RPM after 30sec.
    I have also recently replaced the thermostat to one that opens at 81deg.
    Is it an issue with the chip or the MAF?
    Can anyone help?
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    What sort of LPG system is it running?
    What fuel is it running when having the start up/idle issue?
    So you have essentially 3 pipe inlets into the standard L67 Airbox..?
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VY S/C Calais
    Apr 2011
    Merriwa WA
    I have a PRINS system and I only use 98RON when starting and then LPG.
    The problem doesn't occur once the car has warmed up, only from cold in the morning. (These pics are before the LPG conversion).
    No I have 2 inlets into the airbox (one uses the existing hole and another on the inside) both of which are 4inch (100mm) in diameter. One goes behind the lights and the other goes down below the radiator but not directly under the car for clearance. I will be posting pics when I take them next.
    Idling issues after Cold Air Induction VY Calias S/C with LPG-dscf0584.jpgIdling issues after Cold Air Induction VY Calias S/C with LPG-dscf0558.jpgIdling issues after Cold Air Induction VY Calias S/C with LPG-dscf0554.jpg
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Quote Originally Posted by galerod View Post
    Click image for larger version.
ID:	117340Click image for larger version.
ID:	117341Click image for larger version.
    Easy fix, take it to an LPG workshop and get the idle mixtures and start up tune re-calibrated. I've had a the same issue before.
    1997 VS II - S
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    EDIT: Double Post
    1997 VS II - S
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    Introducing more or bigger holes into the std S airbox shouldn't have anything to do with the idling when cold.
    If there were no problems before you did the mod then I would be looking at something else like a split vacuum hose or air temp sensor (The one on the air box) not plugged back in.
    Its amazing how often guys have problems after mods only to find out it was something simple.
    As said before if the problem didn't exist before the 2 hole mod then something else is causing the problem not the 2 hole mod.
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Quote Originally Posted by Surfwagon View Post
    It could possibly be the vaccum hose or the temp sensor not plugged into the box properly. However, the slightest change of airflow on an LPG run car does present adverse affects, particularly on start up and idle, given the volatility and sensitivity of the fuel, needing the tune to be far more precise than that of a Unleaded run car.
    1997 VS II - S
  1. Climate Control related to idling issues
    By sjmcc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2011, 05:22 PM
  2. Cold air induction.
    By soop in forum General Discussion
    Last Post: 22-12-2010, 11:35 AM
  3. idling issues
    By base308 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-09-2010, 05:38 PM
  4. [SA] Fs: Vy v6 cold air induction(ss induction)
    By exec24 in forum Parts And Other Items For Sale
    Last Post: 14-06-2010, 07:44 PM
  5. 304 Idling issues. o2 sensor?
    By GTP 85 in forum V8 Development and Modification
    Last Post: 12-11-2009, 01:57 PM
