Results 1 to 16 of 16
Like Tree2Likes
  • 1 Post By VN_Luke
  • 1 Post By 0081
Thread: a/f gauge
    vy supercharged
    Apr 2011
    darwin
    Default a/f gauge
    hey i have a s/c vy and iam wiring in a air fuel gauge where go i wire in the O2 sensor signal wire as to get a good reading.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    you could wire it to the interior light for all it matters... you'll get the same amount of information from it
    (google narrowband vs wideband o2 sensor)
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by VN_Luke View Post
    What he says. If your car is otherwise stock then the fuel maps are exceedingly good. If you have a tune done then a a/f gauge will help but your tuner should have one + install a wide band o2 sensor to feed it.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vy supercharged
    Apr 2011
    darwin
    i got the a/f gague with my boost gague and my cluster has 2 gauge mouts in it so it will only be for show
    VY s m5 supercharged
    Aug 2008
    Reaper
    You guys realy have no idea about the A/F gauge going on your comments. One of my gauges is an A/F gauge and it has been the most useful gauge i have as it was showing me my motor was running lean in the top end due to a dirty maf. once i noticed the gauge leaning out and i was paying attention to the motor i could hear the smallest amount of pinning coming from my motor.
    Yes it will bounce around a bit untill you have a tune but to say its useless well your just wrong
    vy supercharged
    Apr 2011
    darwin
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by 0081 View Post
    Do you have a WB or standard NB 02?
    Reaper
    Reapers Black VP SS
    vy supercharged
    Apr 2011
    darwin
    Aug 2008
    mine is using the factory sensor on the passenger side exhaust via the purple wire. However the super charged motor has the 4 wire sensors so it might be a different colour to my na vy.
    Yeah the gauge will move all over the place and look stupid but you need to know how to read it.
    It will work better once you have a tune.
    vy supercharged
    Apr 2011
    darwin
    vyseriesII's Avatar
    vyseriesII is offline The V6 is MACEd
    2004 Vy S Series II
    May 2011
    i have a N/A VY and it has 4 wire o2 sensors?
    Aug 2008
    Quote Originally Posted by vyseriesII View Post
    I was under the impression that the supercharged motors had the 4 wires and the NA motors had the 2 wires, going my your user name you have a series 2 so i guess that some where along the line holden changed them
    Aug 2008
    Quote Originally Posted by plevdog View Post
    is there a way to wire it in after the 2 sensors meet to go into the ecu
    you just need to find out which wire is the signal wire and tap into it. the sensor will send into to the ecu as per normal and the gauge will also get the signal
  15. #15
    vyseriesII's Avatar
    2004 Vy S Series II
    May 2011
    Sorry for the hijack OP ;p
    Interesting, i wonder if my whole loom is the same as the supercharged then. I knew the series 2 had higher flow cats like the supercharged. But i didn't know this. Judging by the date the car was made, it would of been close to the last off production line in the VY series. Maybe they ran out of the N/A looms lol.
  16. #16
    vy supercharged
    Apr 2011
    darwin
    how do u tell wat one the signal wire is cause i know from the ecu wiring diagram that each of the o2 sensors have 2 wires that run back into the ecu (D13 & D14 for the right bank and D15 & D16 for the left bank)
  1. Possible to splice a voltage gauge to pre-existing voltage gauge in dash?
    By VLC86 in forum Electrical Wiring / Questions
    Last Post: 16-12-2010, 06:30 PM
  2. Fuel gauge dead. Speco gauge?
    By blinky666 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-08-2010, 04:54 PM
  3. temp gauge an fuel gauge not working
    By nathan_867 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2010, 10:55 PM
  4. Who's got an A/F Gauge in there VL ?
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-03-2009, 12:58 AM
  5. Auto Gauge 2"/52mm Smoke Series Boost Gauge w/ FREE gauge cup
    By pepstar87 in forum Parts And Other Items For Sale
    Last Post: 16-05-2008, 01:16 PM
