Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: Eonon G2213D Steering Wheel Controlls
    MEESEN's Avatar
    MEESEN is offline V8 6 Speed coming :D
    '03 VY
    Jun 2010
    Default Eonon G2213D Steering Wheel Controlls
    Hey guys,
    I know this subject has been covered ALOT before but i'm not quiet sure on what i can do...
    I have just bought the following head unit "http://www.eonon.com/Car-GPS/2-Din-Car-GPS-DVD/G2213D.html" for my VY
    What I'm wondering is it possible to keep the use of the steering wheel controls? I understand that there are cat10's and PAC audio things but form what I can see they only are compatible with big name brands like JVC, Sony etc... anyone have any idea?
    Thanks Guys
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Reading the manual - it looks like the headunit itself has a built in decoder and you set the control functions yourself. However - the instructions are sparse, to say the least ... If I can be confident on setting the steering wheel controls myself, imma buy an eonon unit myself.
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    MEESEN's Avatar
    '03 VY
    Jun 2010
    yeah i dont really understand them either haha, what do i connect the swc wires from the new headunit to :S
    MEESEN's Avatar
    '03 VY
    Jun 2010
    found this on a facebook page...
    If my car can use Steering Wheel Control with Eonon units, how to wire the cables to make it work?
    P.S. This method can be applied to all the Eonon units which with Steering Wheel Control function.
    There are 3 or 4 cables:
    A steering wheel control power cable +5 V
    A black ground cable
    One or two digital cable(s)
    1. After connecting these 3 or 4 cables, enter the steering wheel setting menu.
    2. Press the steering wheel button of your car, then you can see the Eonon unit will display the voltage of the button.
    3. Press the “SET KEY” icon to set up the function of the button. For example, if you want to realize volume + function , just press the VOL +,and the screen will show you VOL + .
    4. Press the Enter button in the right bottom to save the settings.
    5. Other buttons can be set up in the same way as above.
    Jun 2005
    Brisbane Bayside
    I have done this in prvious cars - VS and VX - via a pac swi unit. It looks like perhaps the eonon unit has the interface built in to the system.
    Setting the buttons seems straight forward enough once the wiring is correctly connected.
    From the wiring diagram in the eonon manual, there are three wires - numbered 6,7,8. 7 gets wired to GND. Easy.
    The hard part is the wiring.
    Steering wheel controls on the VX involved 2 wires - a black yellow wire, and a brown wire.
    When using a pac swi unit, the black yellow wire needs to be grounded and the brown wire sends the signal from the steering wheel controls (by providing different resistance to GND).
    So, according to the eonon manual, wire 7 on the back of the unit needs to GND
    That leaves wires 6 and 8 on the unit
    and there is a brown wire, and a black/yellow wire from the steering wheel controls.
    A little trial and error may answer the next question ...
    Of corse, it is also possible that the unit, and our cars controls may not be compatible ...
    MEESEN's Avatar
    '03 VY
    Jun 2010
    where's a good spot to pick up them wires (Brown & black/yellow) or are they directly connected to the headunit?
    thanks heaps mate things are starting to make sense
    Jun 2005
    Brisbane Bayside
    THose wires are a part of the harness that plugs in to the back of the factory headunit.
    MEESEN's Avatar
    '03 VY
    Jun 2010
    GOOD NEWS!... well kinda...
    I wired up the headunit yesterday (also the steering wheel controlls) but nothing happened... then that night i realised that i wired the wires from the headunit to the yellow & black wire not the black & yellow wire
    But anyway tonight i changed the wires temporarily (because i couldn't be bothered soldering and that)... I then went into the settings and was able to select volume up and down! YAY!...
    Only problem was that when i went to use them later the volume kept increasing after i pressed the volume up button (on the steering wheel)... I could also press the volume down button on the SWC but as soon as i let go of the button it kept increasing... i think it may have something to do with the temporary connection AKA holding the wires together hahah but ill let you all know when i get a proper chance to wire it all up properly
    Jun 2005
    Brisbane Bayside
    Sweet - sounds promising. I have ordered my eonon unit
    MEESEN's Avatar
    '03 VY
    Jun 2010
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by Kudos_0743 View Post
    lols, that is good to hear
    MEESEN's Avatar
    '03 VY
    Jun 2010
    plus i just read that the cat10 interface requires the black/yellow to be grounded so i recon that ill be able to get it going next time i pull it out
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    if you do get it going, you tell us exactly what you did plawx if it works id be happy some1 found a way
    Jun 2005
    Brisbane Bayside
    I ordered mine from eonon US website - free postage, great exchange rate at the moment and 20% - 25% off most units at the moment - (making way for new models ?) About $40 cheaper than buying from ebay.
    I had expected tv reception would not be much good - but then, analogue is near dead here in AU anyway. I won't even bother with a tv aerial.
  15. #15
    MEESEN's Avatar
    '03 VY
    Jun 2010
    mines dvb-t (digital tv) but yeah aerial taht it comes with is shite...
    ...and ill let ya's know the wiring if it works out
  16. #16
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    yay thanks, with the tv the new one im getting is $50 cheaper without the areal and the head unit doesnt support DTV which i dont care coz i dont use the tv anyways
  17. #17
    MEESEN's Avatar
    '03 VY
    Jun 2010
  18. #18
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    haha i just wanna be able to chill and watch tv when im bored in traffic haha
    for me, thats what the sub is for "back massage YIPPY"
  19. #19
    Jun 2005
    Brisbane Bayside
    <...> But anyway tonight i changed the wires temporarily (because i couldn't be bothered soldering and that)... I then went into the settings and was able to select volume up and down! YAY!... <...>
    So you can confirm the eonon headunits can be controlled by vy steering wheel controls without an interface?
  20. #20
    MEESEN's Avatar
    '03 VY
    Jun 2010
    ill cant be certain but im pretty sure its a yes... but it may not be compatible as it may just keep doing what it was doing (volume increasing)... If i get off work early tommorrow ill have a go at wiring it properly
  21. #21
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    any luck ?
  22. #22
    MEESEN's Avatar
    '03 VY
    Jun 2010
    Didn't get a chance tonight mate work kept me back ill try to make time tommorrow after work ill let yas know asap
  23. #23
    Jun 2005
    Brisbane Bayside
    Sweet. I am hoping to recieve my unit tomorrow
  24. #24
    MEESEN's Avatar
    '03 VY
    Jun 2010
  25. #25
    Jun 2005
    Brisbane Bayside
    lol - so I'll have it sorted for myself before you let me know how it's done?
    I got my unit, but yet to get harness adaptor...
  1. Eonon Double Din Deck - Wheel controls?
    By Skeptical in forum Car Audio
    Last Post: 26-02-2011, 08:06 PM
  2. [ACT] MOMO steering wheel & no brand steering wheel
    By calais24/7 in forum Parts And Other Items For Sale
    Last Post: 23-02-2010, 05:33 PM
  3. Stereo steering wheel controlls not working
    By chud_man in forum Car Audio
    Last Post: 23-06-2008, 09:48 AM
  4. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
