Results 1 to 21 of 21
Thread: Vy ticking problem!
    VY S pack ute
    Mar 2010
    Default Vy ticking problem!
    Iv got a vy series2 spack 3.8.. And its got a real bad ticking problem
    I replaced the lifters yesterday and if anything, the noise has got worse.. Any
    Ideas to wat the problem could be?
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    I had a ticking problem a while ago in my vz, turns out I had blown my cat converter and all the insides were rattling around?
    VY S Series 2
    May 2010
    the ticking noise could be a few things... does it get louder with temperature or when under load? is it all the time or just some of the time?
    VY S pack ute
    Mar 2010
    Its not the cat cos i dnt have 1.. Comin from behind throttle body only.. And is noisy all the time.. Its deff lifter noise.. I was thinking oil pressure?
    VS V6 Acclaim
    Jul 2008
    Could be timing chain stretched out or damaged cam lobe from sticking valve or old lifter.
    You can feel a knackered timing chain with the accessory belt off, plugs out and rock the harmonic balancer/crank back and forth with both hands.
    It will slap if it's the problem.
    Lobe damage can be seen by turning the engine over by hand slowly with the plugs again out and the rocker covers off.
    Closely watch each rocker action for any sticking or strange action.
    VY S pack ute
    Mar 2010
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    Quote Originally Posted by beauza View Post
    Why not???
    VY S pack ute
    Mar 2010
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    I thought the lifter noise was ' standard' in the ecotec.. its a known issue..
    I notice mine goes away after a fresh oil change..
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    VY S pack ute
    Mar 2010
    It is a known issue but mines louder than normal.. Nothing iv tried has worked.. Replacing them, additives etc etc
    I had a listen last night and im sure its coming from the inlet manifold
    VS V6 Acclaim
    Jul 2008
    The valley cover on the inlet manifold is only 7-8mm thick and readily transfers noise from underneath it.
    The only thing thats in the manifold that it could be is the pcv.
    I'll post a pic in a sec of a cam I just pulled out of an eco with 190k on it. Was a stock old mans car with a sticking valve/lifter.
    If the lifter repeatedly loses contact with the cam it grinds the top off the lobe real fast.
    Back in 10.
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Smashed it out..
    awww mate your car is fulll hectic now!!
    RIDE:42's Avatar
    RIDE:42 is offline crew chief
    vuss
    May 2009
    Have seen the serpentine belt (big long fan belt) that are old or have gotten hard and have cracks in them make ticking noises ,spray some water on it at idle and see if it quietens if it dose go get a new one.
    VS V6 Acclaim
    Jul 2008
  15. #15
    VS V6 Acclaim
    Jul 2008
  16. #16
    VY S pack ute
    Mar 2010
    Il give the belt thing a go.. I got told it cld be the cam but are there any other sounds associated with that being the problem?
  17. #17
    VS V6 Acclaim
    Jul 2008
    No other sounds. It just sounds like a lifter but worse.
    If you can turn it over by hand while watching the rockers closely a damaged lobe will make one of them not get full lift and open and close strangely. If a valve is sticking, the rocker will go loose and float.
  18. #18
    VY S pack ute
    Mar 2010
    Il have to try it.. Saw a guy before and oil pressures good, so only thing left is cam how much is an aggressive cam for the ecotecs?
  19. #19
    vn hsv wagon
    Apr 2011
    Frankston
    Mate how many kms and has it been a serviced car as the one killer of holden v6 is oil changes.look in the cap ,is it clean or claggy.If not a serviced car they do liffters and spin bearings
  20. #20
    VY S pack ute
    Mar 2010
    Looked under the rocker covers with a mechanic and wen changed the lifters n he said its the cleanest v6 hes ever seen 175 000 kms but have another engine @ 100 000kms to replace if needed
  21. #21
    VY S pack ute
    Mar 2010
    I got stock at 137 000 but pretty sure its been thrashd before me
  1. Ticking behind dash (no, not injectors or lifters ticking)
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2009, 01:20 PM
  2. VT blinker ticking problem
    By vlv8vic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-10-2008, 09:48 PM
  3. Problem with oil light & ticking VS
    By lynnie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2008, 07:45 PM
  4. problem starting car, keeps ticking over but never fires
    By Caprice5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2007, 07:44 PM
  5. VT ticking problem.
    By sparra_gump in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2006, 08:32 AM
