Results 1 to 4 of 4
Thread: Vy auto gearbox issue
    VY Exec N/A Auto
    May 2005
    Geelong, Victoria
    Default Vy auto gearbox issue
    Ok so my fiancée owns a vy v6 series 2 auto ute. Trying to drive it the other day and put it in drive and it would just rev, so turned the car off and back on and it would go into drive and we could drive but if we got above 60 it would lose it's gear completely again, and the car would just rev like it was in neutral. Also the other issue is that her computer thing on her dashboard randomly restates when driving, not sure if that is linked since I heared that the gearbox is electronically controlled. I tired putting the car in 1st or 2nd to see if it would work but nothing oh and also tried reverse. The car is. Over 2 hours away so I can't try anything else but yeah wondering what it could be. Sorry for no paragraphs this is off my iPhone cause my computer died aswell so bad week lol. Thanks in advance for any help
    1.91 rockers, 69mm throttle body, bmc panel filter, electronic shift kit, plenum spacer, manifold insulator, pioneer 7inch 6 stacker dvd player, 2*12inch subs- custom fibre glass boxes
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    above 60 light accelerator is top, using most oil of all gears to maintain it.....
    check the basics first oil level?(duh)
    engine lights on when idling in nuetral? (code check in case ecu failure (pcm failure means engine and trans here)))
    if it doesnt select a gear in manual mode and revs too high at 60 could also be the selector arm broken at pivot underneath or come loose......
    00 SS M6/79 chev Monza
    Mar 2005
    at a guess i would either say its either low on oil or the governor gear ...
    VY Exec N/A Auto
    May 2005
    Geelong, Victoria
    Thanks for the help I won't get to look until tommoz, let's hoping it's just low oil
  1. 89 VN Gearbox issue
    By Sgt Santa Cruz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2008, 07:32 PM
  2. vs ii gearbox or other issue
    By Garth in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2008, 11:11 AM
  3. Gearbox issue
    By mess666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2007, 08:09 PM
  4. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  5. Gearbox Issue!
    By Emackulation in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 01:16 PM
