Results 1 to 4 of 4
Thread: Supercharged VY Hesitation
    VY Commodore S Supercharged
    Apr 2009
    Default Supercharged VY Hesitation
    I have a Supercharged VY Commodore with a 10 psi upgrade and induction kit. The problem i am having is with it's hesitation. When taking off from the lights or when already at speed it seems as though it is not getting enough power. Under the excelerator and you feel and hear that it silghtly hesitates in giving me it's all. When already at speed like over 60kms and you flatten it, it makes this chucking sound briefly. After changing the leads and plugs to decent quality (one of the previous plugs was cracked) i found that it was better for about a week but now it's back and getting worse. Has anyone had the same issues? Does anyone know what may be causing this?
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    As above, i'd next be looking at Coil Packs and DFI Module. Very quick and simple to test with another to eliminate them as the problem source. Do you know anyone with a vs-vy v6 you could borrow them from to test on yours? They are the same from vs-vy v6 ecotec and supercharged. I've attached a pic to help identify. The DFI module is the flat alloy plate sandwiched between the coil packs and the metal mounting platform. It has the wide electrical plug attached on the side held in by one 6mm bolt. The fine bolts holding on the coils are 7/32, not metric.
    Hope that helps.
    Cheers,
    Chris
    Attached Thumbnails Attached Thumbnails Supercharged VY Hesitation-l67-coil-packs.jpg
    VS L67
    Sep 2007
    BrisVagus
    What plug gap are you running and what fuel are you running?
    When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
    353RWHP L67 VS S Pack 6 Speed
    Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
    W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
  1. VE SS hesitation
    By Homer's HSV in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-03-2010, 02:55 PM
  2. vt v6 hesitation when accelorating
    By showbags in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2010, 07:17 PM
  3. vs v8 misfire\hesitation HELP!!!
    By vs_grunta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2009, 05:34 PM
  4. Engine Hesitation
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2009, 09:32 PM
  5. Throttle Hesitation
    By Slippy_Trippy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-06-2009, 08:51 PM
