Results 1 to 6 of 6
Thread: Vy Commdore Ute Aircon issue
    Vy Commodore ute 3.8l
    Jun 2011
    Newcastle
    Default Vy Commdore Ute Aircon issue
    G'day,
    I'm hoping someone can off me some advice on my VY.
    When i turn my aircon on it makes a loudish tapping/banging noise coming straight from the compressor it still pumps out cold air though and the pipes to the compressor look like they are vibrating.
    I'm guessing the compressor is cactus.........so im thinking i need to replace it but im not paying joe bloggs $1300 to do so.
    Is it hard to replace? I have a mate that can gas it for a slab........
    Any advice would be good!
    Shermo
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    have you checked that it's bolted onto the motor still?
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    Jun 2011
    Newcastle
    That is a very valid point! I will check tomorrow but i think it is as the compressor itself doesnt appear to be moving just the two pipes.
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by Shermo View Post
    G'day,
    Shermo
    Sounds like the comp. Check if it is bolted on properly and nothing is vibrating on the comp.
    But you cant just unbolt the comp just like that. You have a thing called refrigerant and you cant let this go out to the atmosphere you need to reclaim the gas.
    Jun 2011
    Newcastle
    The compressor is bolted in properly so i am going to replace it, I'll get my mate to reclaim the gas and then regas when i'm done.
    does anyone know what the go with the oil in the compressor is? and how much gas needs to go in?
    cheers
    Mar 2008
    It's written on the sticker on the radiator shroud.
  1. Aircon weird issue
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2010, 12:01 PM
  2. VT Aircon Vents Issue
    By Penguin360 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2010, 09:30 PM
  3. Vt series 2 aircon issue!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-11-2009, 01:21 AM
  4. electrial / aircon issue - s2 VN SS
    By Jazack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2009, 03:04 PM
  5. lectrial / aircon issue - s2 VN SS
    By Jazack in forum Electrical Wiring / Questions
    Last Post: 06-03-2009, 08:50 PM
