Results 1 to 12 of 12
Thread: Ss clutch
    VY SS
    May 2011
    Auckland
    Default Ss clutch
    Hey all,
    My clutch engages at the very top so it's probably not far off going. Ill wait til its slipping before i change it though. Went into Holden today to get a price for the parts. I'll most likely do it myself.
    They quoted me $1478nzd for the clutch assembly (including new fly wheel) and $474nzd for the release bearing. Both ex Australia.
    Is it worth changing the flywheel or should I just skim it?
    What are your recommendations? Is it a fairly straight forward job (normal rwd clutch)? Aftermarket or genuine part?
    Cheers Taylor
    Kingston_99's Avatar
    Kingston_99 is offline 383ci HTV2300 blown LS1!!
    VY SS ute STROKED/BLOWN
    May 2010
    Mount Isa
    you would be better of just getting a single plate heavy clutch. something on the lines of NPC or the Tex X
    they sholud be around the 1200 mark from memory.
    but if you plan to do some work down the track, i would think twice about what sort of clutch you put in it now.
    want to see more then a typical commodore fitted with an exhuast, then check my thread out... link broken cuase i dont own a tuff car, i just made it up...
    VY SS
    May 2011
    Auckland
    Good point. I'm putting headers and full exhaust on it. Could be tempted by a lumpy cam and tune too. I won't be going forced induction due to insurance.
    From what it seems it's the same clutch as the r8s etc, they're making quite a bit more torque than I am currently.
    I'm in nz though. Wonder if theyre available here or what shipping would cost me.
    May 2010
    Mount Isa
    im not realy sure.
    if you are just going to have a exhuast and cam, the standard clutch will hold out. but if it were me, i'd stick a heavyer clutch in. single plate will do the job fine and still have the stock pedal feel.
    VY SS
    May 2011
    Auckland
    Yeah I see what you mean. Stock or heavy duty were the two options I was thinking. pedal feel was one things slightly steering me towards genuine. But if single plate should get me a similar feel that's more appealing
    Would you replace the flywheel or just skim it?
    VY SS
    May 2011
    Auckland
    Gm ones are so cheap in the states. Such a pity shipping would rape me.
    Is there any reason to replace the flywheel as opposed to skimming it?
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    We usually just machine the flywheel at work. If its the first clutch that you are putting in your car then theres no need to get a new one. Just skimming it will be fine.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    VY SS
    May 2011
    Auckland
    No 100% sure whether it is. I wouldn't think it's done 2 clutches in 150k though ...
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Yeah but even if it is the second clutch you should still be right. But I can't see your VS SS needing a second clutch already, i'd say it would still be the original one that it came out of the factory with. We have never had a customer come back because there was a problem with a clutch job. Sometimes we just roughen the flywheel with sand paper and it works fine, but depends how much the customer wasnts to spend. Just get yours skimmed, I can't see you having any problems at all by doing that.
    May 2010
    Mount Isa
    standard flywheels are pretty thin...
    when you buy an aftermarket clutch, it comes with a flywheel.
    i'd get an heavy duty clutch kit bro!
    dont waste time on a standard crap...
    VY SS
    May 2011
    Auckland
    Any brand recommendations?
    Pontiac gto clutch and flywheel from gm for 440usd +250us shipping is winning at the moment.
    Wouldn't I loose power with a heavier flywheel?
    VY SS
    May 2011
    Auckland
    Bit of an update here.
    I've sourced a GM clutch plate for 600nzd and aftermarket release bearing for 100nzd.
    Ill skim the flywheel and re-use the pressure plate. If i have to take it out and redo it again in a couple of years so be it. I cant afford the full assembly at the moment and i want to do it before its slipping too badly since i wish to reuse parts. Ill check out the slave assembly for leaks while I'm in there, and change the clutch fluid and gearbox fluid.
    My manual says that the 6 speed manual transmission takes dextron III fluid and doesn't have a capacity. Isn't this automatic transmission fluid? Does anyone know how much it takes?
    i read somewhere you cant reuse the flywheel bolts is this true?
    Im probably going to buy a workshop manual and ill be learning as i go but is anyone interested in a how to?
    cheers for the help all
    edit: did some more research today. nobody will skim a dual mass flywheel.
    going to get the acdelco pontiac gto clutch. Will post up so everyone else can save money too if it fits without problem.
  1. clutch is making a loud pop sound when i push the clutch in
    By giffo2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2011, 04:37 PM
  2. ssv ute clutch
    By peteyb12 in forum VE Holden Commodore (2006 - ?)
    Last Post: 18-01-2011, 01:16 PM
  3. vx ss clutch ??
    By Sir VxSs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-11-2010, 11:45 AM
  4. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 11:22 PM
  5. v8 clutch kit
    By griffindore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2006, 11:40 PM
