I just wondering how your meant to put the little metal 'hats' on the rear exhaust mounts that hold the rubbers in place. I had to replace the rubbers but i cant figure out how to get the hats to go back into the little groove.
I would like to know too cause I want to change the rubbers on my exhaust.
It been making this high frequency squeaking / vibrating noise while idling and it's irritating.
Check out My WL CAPRICE
http://forums.justcommodores.com.au/...price-l-k.html
If you opened them up a bit to get them off, you will need to squash the tabs back down a bit, then just push them over the pin until they clip into the groove. Sometimes a screwdriver helps, sit the clip on the pin, then push it on with a screwdriver.
its a pain, but you just push them on till they clip in the grove
