Results 1 to 17 of 17
Like Tree4Likes
  • 1 Post By TMM
  • 2 Post By VjamesY
  • 1 Post By Mohi
Thread: What's involved in lowering a VY?
    Ignited-SV6's Avatar
    Ignited-SV6 is offline Sleek and Class
    VY Berlina
    Jun 2010
    Default What's involved in lowering a VY?
    Hey guys n girls,
    I've just upgraded my brakes to slotted with remsa pads (thanks GSL RallySport!) and it's rekindled my love for my VY Berlina.
    I want to lower my car so that the wheel arch is slightly over the 18" rims.
    What's involved when it comes to buying lets say King Spring SL? do I need new struts or anything? How much will it cost to lower?
    Cheers!
    PS Still looking for a HBD front lip, the one I had was cracked.
    My Ride
    http://forums.justcommodores.com.au/...a-ss-rims.html
    Next mods: Lowering, 4 Channel Amp and eventually 19's
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    If you're going super low, it would be best to match it with some shortened shocks in order to retain ride comfort and improve the performance. We do it as a package deal:
    KYB / Kings Commodore Lowering Packages!
    Kings and KYB's to suit are $675. Ideally you'd also want a 4 pt camber kit (though this isn't 100% critical) and a Whiteline one to suit is $175. Shipping to Melb would be $22.
    Any questions at all just let me know!
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    VZ AWD One Tonner
    Jul 2006
    They're good, not great. For the few extra bucks most would take the KYB over the Tenneco shocks...
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    As what either Nic or GSL says, up to you which springs/struts you prefer.
    VY's don't really need camber kits though, unless you want it PERFECT but i don't think that's even possible. Mine with the lowest springs i can go does camber the tiniest bit. You can't even notice, it looks straight. SL's should be fine
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    03 VY Exec
    Feb 2011
    VIC
    say im lowering mine SSL's all round and i have mine on 18's, i wouldnt need a camber kit?
    VY Berlina
    Jun 2010
    Pedders say they'll put on just the springs including installation and wheel alignment for $660.
    From others expirience, is it worth getting just the springs to start off with? and then if I want it put on the shocks later.
    My Ride
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by Ignited-SV6 View Post
    id just do the shocks and springs at the same time
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    $2 grinding wheel and a mates Makita.
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    SL/SSL on tired standard/FE1 shocks will handle like complete crap. The FE1 shocks aren't a high enough rate to control the springs, so they will bounce a lot. Also it's unsafe because the FE1 shocks are not short enough to capture the springs - that is if the suspension goes to full drop, such as when you jack up the car, or drive over a large pothole, the spring will be loose.
    Also get some new strut tops (with bearings) because they will most likely be very worn. The castor (radius rod) bushings will also be on their last legs if they haven't been replaced before.
    Quote Originally Posted by DevilDRake View Post
    Have you had the front camber reset though? If you just change all 4 springs it's not noticeable because the front will be cambering too. When you align the front end it makes the rear camber a whole lot more obvious.
    The VY rear end doesn't offer that much improvement over VT/VX1 in terms of camber. You will still chew out tyres on SL and lower springs without a camber kit, just not as badly as a VT/VX1.
    My VY has at least 1 degree of negative camber on the rear and i've only got King "lows". I don't care though because i don't do many kms and will probably have to bin my tyres of old age rather then wear...
    It would definitely be beneficial to fit a camber kit to a VY if you are putting in Super Lows.
    For SSL/SSSL you should fit a camber kit but it's like pissing on a bush fire, the kit might give you 1 extra degree of adjustment but when you're trying to get rid of -3.5º you're still up shit creek...
    You only need a 2 point kit for a VY because the other 2 'points' (such as in a 4 point kit for a VT) are for toe adjustment, and the VY has a toe link that already provides adjustment for that. Attempting to put a 4 point eccentric bushing kit in a VX2/VY/VZ will result in the suspension binding up and excessive stress on the bushings. Some places will sell/install the same 4 point kit as a VT/VX1 and remove the toe links. This is pretty dumb because it reverts the suspension toe dynamic back to that of a VT/VX1 which is inferior to the VY/VZ setup. The only '4 point' kit that should be put in a VX2/VY/VZ is the normal 2 point kit (eccentric bushings), and replacing the other 2 points with a non-adjustable type bushing (non-eccentric) simply because of general wear and tear on the original bushings.
    vy commodore executive S2
    Jan 2011
    Yup, i think you will be fine, as i had my vy lowered few ,months back for only $380 from tyre factory including all new low king springs with stock shocks and its all good , i got 18's and the body sits just on the top of tyre,...
    VY Berlina
    Jun 2010
    Quote Originally Posted by Mohi View Post
    Got any pics of your car?
    Still unsure whether to lower it without shocks first. I'm getting the HBD front lip first and the rear calais skirts. I'll probably look at lowering toward the end of the year.
    My Ride
    VY executive
    Oct 2008
    I have sl kings in my vy executive with the kyb short shocks provided by gsl rally and can only further recommend this combo. Havnt had one problem and the shocks have been going strong for about a year now. Car rides great to.
    Jan 2011
    At the moment am at work , so cant upload them , company policy but will do as i reach home.
  15. #15
    Jan 2011
    So here is my vy with kings springs with stock shocks.....
    Attached Thumbnails Attached Thumbnails What's involved in lowering a VY?-car.jpg
  16. #16
    VY Berlina
    Jun 2010
  17. #17
    Jan 2011
    Are those 18" rims?
    Yup ... they are 18's
  1. [VIC] What's involved?
    By Gunns VC in forum General
    Last Post: 08-12-2010, 07:17 AM
  2. Cam swap - what's involved??
    By savage1987 in forum V8 Development and Modification
    Last Post: 22-02-2008, 08:11 AM
  3. Whats involved??
    By hothead115 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-07-2006, 06:39 PM
  4. VN V6 Turbo, what's involved
    By greenfoam in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2005, 10:58 PM
