Results 1 to 6 of 6
Thread: VY issues, advice needed! Pictures included.
    VY Acclaim Wagon S2
    Jul 2011
    Default VY issues, advice needed! Pictures included.
    G'day, I'm new here!
    My series 2 VY Acclaim wagon has provided me with many trouble free years of service.
    It is still running great, however a few issues have arisen which I want to get on top of.
    I'm normally a french hot hatch specialist, so some newbie advice is needed.
    Firstly some surface rust has started to appear on the left frame rail in the engine bay.
    The photos make it look worse than it is, however, I want to treat it ASAP. The rail is still very solid, so the rust is not bad. I wonder how this happened? The car hasn't been in any accidents as I am the original owner. I do alot of highway driving in the wet though.
    Now I know the rail is solid inside, but apparently you can get internal frame coating cans.
    Anyhow, how would one treat this at home? Any ideas?
    Secondly the two heater hoses that come from the fire wall meet at a junction. It is leaking. Any advice here would be great too!
    Thanks in advance.
    VYII Equipe S/wagon V6
    May 2009
    Melb, Vic
    Hows the brake fluid level? As that'll eat through the paint quick smart if not washed off.. Mind considering that the coolant seems to be leaking away, that stuff is like sugar soap.. Without pulling your hose's off I think you should just purchase a new heater flow regulator and/or associated hoses (If they look even slightly dodgy). After you fix all the leaks you'll have to treat the area with a rust inhibitor and looking at the pictures I'd go banana's with the stuff.
    Cheers,
    Dave
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    replace the heater tap.. costs about $25 from an auto store... and about 20-30 mins to replace also buy some coolant and do a flush at the same time.
    VY Acclaim Wagon S2
    Jul 2011
    Thanks for comments so far.
    Can you just apply rust inhibitor or is it best to sand back the area as best you can first?
    May 2009
    Melb, Vic
    Follow instructions on supplied rust inhibitor product. I would clean as much as possible otherwise it'll look like a dogs breakfast :P
    Cheers,
    Dave
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    As caaf said, brake fluid is very corrosive if left on paint. It won't affect the metal, but will leave it without any protection against surface rust. If you combine leaking brake fluid and coolant in the one spot, you'll get plenty of surface rust like you have. I think coolant is also capable of damaging paint so that leaking valve might be the only culprit.
    Check the master cylinder and ABS module for any signs of leaks. As already said, it would be wise to replace any heater hoses that are looking dodgy. In particular, the hose which flares out as it fits over the water pump outlet is a known weak spot as the flared portion of the hose has thinner, weaker walls and is generally the first place to split.
  1. Engine FAN Relay 1 Melts, Help needed.....(Post with Pictures)
    By frontier in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-06-2010, 02:36 PM
  2. New ASR Website - Your Pictures needed!
    By rch-13z in forum ASR Audio & Electronics
    Last Post: 20-02-2010, 10:42 PM
  3. Cold Air Intake Pictures Needed
    By Butso in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-10-2005, 10:20 PM
