Results 1 to 11 of 11
Thread: vy ss m6 ticking
    Vr Series 2 S-Pac (Manual)
    Aug 2009
    Default vy ss m6 ticking
    helllo, i have recently upgraded to a vy ss ute and have noticed a ticking noise coming from the gearbox.
    its like a ticking noise that speeds up and slows down accordingly to my speed.
    when i speed up, the ticking speeds up, when i slow down, the ticking slows down.
    sorry if this is in the wrong section :|
    any help would be greatly appreciated xx
    My Life Be Like,
    RadHuh
    Aug 2009
    VY II V6
    Dec 2006
    It sounds like one of the exhaust manifold gaskets isn't sealing. You could try to nip up the exhaust manifold bolts a little but don't over tighten them.
    Aug 2009
    Thanksan I'll give that a shot. Appreciate it.
    Also when my car really needs to pull. Example 5th up a hill. I think it might be a pulley squeaking. Sounds like a bearing is gone. Any ideas how to find out which pulley it is ?
    And obe more thing. Will a brand new exhaust stink ? Like when it gets really hot.
    It stunk whe I first got it really badly. But now it's just when I absaloutly give it to it. It ####ing reaks? If it's coz of the new exhaust. How long will this last ??
    My Life Be Like,
    RadHuh
    VY II V6
    Dec 2006
    Once my mum drove over a plastic bag and it had melted onto the middle muffler and your symptoms sound very similar. It could just be a sticker or some tape that is burning. I'd get it checked properly on a hoist just to be sure though. The smell on my mum's car lasted for months and then one day it was gone.
    As for the pulleys, the best way is to cut a length of old garden hose, about a metre will do. You put one end to an ear and the other end near each of the pulleys one at a time while the car is running. You should be able to tell which pulley is stuffed fairly easily. This ticking sound will be much faster than the other.
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    It's rotational what ever the problem is... collapsed cats can also tick @ speed, so be aware of this.
    Recently I thought my gearbox or clutch had shat itself from the noise it was making. In the end I took it to a mates place with a hoist, poped it up and it was both rear CV had collapsed and was transmiting the clunk/tick through the diff-->up the tailshaft--> through the gearbox into the clutch.
    Try this:-
    At 60, push the clutch in but not out of gear - Noise still there then it's from the clutch and back.
    At 60, push the clutch and out of gear - Noise still there then it's from the tailshaft back.
    Problems like this are a real biatche to diagnose... Good luck
    Aug 2009
    Thanks heaps guys really appreciate. I'll try over the weekend.
    The pulley squeal is only when I'm doin really low revs in 4 5 and 6.
    Like when it has to pull.
    I'll try the 60 k thing tomorrow. Thanks heaps man
    My Life Be Like,
    RadHuh
    Aug 2009
    It's only when the clutch goes in. Soon as it reengages it stops.
    My Life Be Like,
    RadHuh
    VS V8 Manual
    Jun 2011
    NZ
    is the smell like sulpher? bet the Cat if so
    VS V8 Manual ... Reppn it for NZ
    undersuspicion is offline Now That's How We Roll!
    Vy SV8 Series 2
    Aug 2010
    Quote Originally Posted by kiwicon View Post
    was thinking the same thing. Might just be the cat.
    don't take this wrong or anything but ARE YOU ####ED IN THE HEAD????
    Reaper
    Aug 2009
    Nha. It's more of a burning smell.
    My Life Be Like,
    RadHuh
  1. 308 ticking bad
    By cjwau in forum V8 Development and Modification
    Last Post: 09-01-2012, 07:53 AM
  2. Fan ticking (A/C off and on).
    By madcowbeavis in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-02-2011, 02:59 PM
  3. vt 5.0l ticking
    By crisp5.0 in forum Just Commodores Polls
    Last Post: 07-01-2011, 04:06 PM
  4. Ticking behind dash (no, not injectors or lifters ticking)
    By Abrowne70 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2009, 01:20 PM
  5. VP Ticking
    By DavoVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2008, 12:00 AM
