Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Like Tree3Likes
Thread: VY 6x9 installment
    VY series 2 Equipe 3.8l ecotec V6
    Jul 2011
    Australia
    Post VY 6x9 installment
    Hey does anyone know if you can wire 6x9's to the stock head unit? If so how?
    Thanks,
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    VY SS
    Jun 2006
    Albany
    do you plan on keeping the rear door speakers? if you are you will need an amp to power the 6x9's, or just disconnect the rear door speakers and run some wire from the 6x9's to the original speaker wires
    Jul 2011
    Australia
    Jul 2011
    Australia
    Quote Originally Posted by axemurderer101 View Post
    Im pretty new to this ay my mate knows a bit but hes not sure. So 6x9's amp as i planned but can they be wired up to the stock head deck or do they have to be wired up some other way?
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    VX 'S' S1
    Apr 2005
    South East,Victoria
    I ran the wires from the rear door speakers to a hi/lo converter then through a 2 channel amp then to the 6x9s
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by Nic92 View Post
    same way you wire the front speakers ?
    you should get all new speakers and amp them up
    Your setup caught on fire and you don't even know how to remove a few screws to access the back of the headunit. Nothing personal, but please don't give advice if you have no idea.
    Quote Originally Posted by jiimbo12 View Post
    Have you got the amp yet mate? If not run the 6x9s off of the rear door speaker wire.
    Once you have an amp for your speakers you will have to run "RCA" cables to an amplifier, and run the speaker cables to the amplifier, not the headunit.
    Amping off of the stock headunit gets a little bit tricky, due to technical reasons (More information on this available here)
    Amping off of an aftermarket headunit is insanely easy, as they are designed for it.
    Let us know what you are trying to do before you keep going (are you just changing the speakers, are you trying to amplify them etc.)
    Good luck!
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Quote Originally Posted by MAG00 View Post
    depends if ya wanna amp them or not mate....
    but I'm guessing you are asking whether there is wires to go off in the parcel shelf? which there isn't.
    So if you want 6x9's on the rear shelf you'll have to run new wires...and they simply take over the rear door
    speakers.
    So you'll have to do some dismantling
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    Jul 2011
    Australia
    Good luck!
    hey um i have put all new speakers in the doors and wanna amp those. also want to put 6x9's on the rear parcel shelf and obviously amp them too. and so yeh i just wanna know how to wire up the 6x9's and amp with the stock head deck. Cheers.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by Dayvo View Post
    +1 to this.
    Or even better, install a sub in the boot instead of 'fully-sick-by-nines'.
    Jul 2011
    Australia
    Quote Originally Posted by kcpwns View Post
    speakers.
    Are you able to run wires off the rear door speaker wire and keep the rear door speakers as well or? Cause i wont all my 4 door speakers and add 6x9's. and amp them?
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    4 speakers on 2 channels and 6x9s on the other 2 channels then set the gains so there all at the same volume
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    You can amp the 6x9's independently if you wish. Would make it easier if you had an after market stereo however.
  15. #15
    VY S/II S Pack
    Apr 2011
    Some people never learn
    /faceplam
  16. #16
    VY SS
    May 2011
    Auckland
    You can loop off the rear speaker outputs to run the 6x9s. I spliced off the rear speaker wires running from the headunit up the front under the trim and ran that to the boot to the high level input on my amp to run my sub. My rears still work.
    Be careful about mounting the 6x9s. It's illegal to cut the parcel tray
  17. #17
    VY S/II S Pack
    Apr 2011
    Quote Originally Posted by m1lky View Post
    I'm under the impression that all VYs have them cut out already, with the pieces of sheet metal held on by a few tabs... ie. the only cutting needed is the parcel shelf cover, which is not the body of the car and therefore not illegal...
  18. #18
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
  19. #19
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    He's right nic... Doing it the way you suggest changes the resistance. Which means you have a chance of damaging the amplifier or speakers or even both if there not designed for it.
  20. #20
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    Quote Originally Posted by wraith View Post
    most speaker amps can take a 2ohm load thou?
  21. #21
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    No they can't. Only the specialist amps are usually 2 ohm. Most consumer amps are 4.....
  22. #22
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    ohh i see alot of 4 channel amps with 4ohm and a 2ohm load
    i am actually sure on this one, every 4 channel amp i have looked at so far have a 2ohm and a 4ohm load
    i am currently looking for a new amp so thats why i have been looking
    2ohm is more rms power but then it gets split into more than 1 speaker/woofer or what ever is connected if it is not a DVC4ohm
  23. #23
    VY S/II S Pack
    Apr 2011
    how about just stfu
    How about stop putting peoples expensive equipment, money, car and possibly life on the line by giving shotty advice conjured from random assumptions. Electricity is dangerous, there's not really any room for error. Just because your s**t caught on fire, doesn't mean everyone else's has to.
    It's pretty stupid to give someone advice based on the assumption that you can throw anything in parallel and it will work. I just picked a random Pioneer Amplifier on the web and it only runs in 4 ohms, you lose.
  24. #24
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    if u aint got nothing nice to say 2 me then dont say anything
    if it wasnt faulty then it wouldnt have, GET UR FACTS RIGHT B4 U JUDGE ME
    if u read the thread u would know i never touched the wiring to the amp, god so arrogant
    ur so annoying stop talking to me already added u to the ignore list so goodbye
    f0cking goober
  25. #25
    VY2 Berlina hail damaged
    Mar 2011
    check out the Phreddy / ASR threads under sponsors they seem to have a system down pat for this problem. I am trying to raise funds for my own mod
LinkBacks (?)
  1. 17-08-2011, 04:25 PM
  1. Speaker Installment
    By saint_matrix in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-05-2006, 12:18 PM
