Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: Oil Pressure Gauge?
    2008 VE 6lt SS Ute
    May 2011
    Question Oil Pressure Gauge?
    hi all,
    I apologise first cause this has more then likely been answered before, but I'm not quite clear of the in's and out's of it.
    I have a 2003 VY SS Ute and I've got the voltage gauge and oil pressure gauges for the car, I'm new when it comes to working on cars, I've done little things like hook up the DVD player and service and all those simple things, but I'm not sure how I go about hooking up the oil pressure gauge, like what do I do with the original sender when I hook the sender for the gauge up, I know I'm sounding like a dumba## but I'm just trying to learn bit by bit.
    a set by step with pictures would be extreamly helpful. thanks guys.
    02 VY SS
    Apr 2010
    Are they aftermarket gauges if so you will need an adaptor to keep the original sendor as it will alrm if you dont.
    2008 VE 6lt SS Ute
    May 2011
    VY SS UTE
    Jan 2011
    SE QLD
    I ended up going with an oil filter sandwich plate (speco make them) gets a much more accurate reading rather than from the oil pressure sensor on top of engine. Plus you'll need a custom adapter if you intend to run it from there.... Super cheap, burson, repco and auto barn had nothing large enough to fit an adapter for the ls1 engines.
    Only other way is to tap a thread into the removable plate under engine next to oil filter.
    Only prob with sandwich plate is that it protrudes slightly and is a tight fit getting the sump shield back on.... However, I've now got two spare 3/8 threads I could maybe use for an oil cooler, but intend to run a oil temp sensor in the future.
    2008 VE 6lt SS Ute
    May 2011
    VY SS UTE
    Jan 2011
    SE QLD
    Sandwich plates are a gadget that screws into the place where oil filter is fitted and then the oil filter screws inside/over it so it acts as a go between. Very easy to set up, about $65 from memory, mind you there's not much room down there and it's fiddly but very doable.
    As I mentioned it comes with three outlets, so it has its advantage if you're looking at adding extra oil gauges. Presently I'm only using the one outlet running my oil pressure gauge via it. The two other outlets are blocked off.
    The gauges I bought were from the USA and were an aftermarket fitment for the Monaro or whatever it was called over in the US.
    The wiring it came with plugged straight into the factory oil pressure sensor on top of motor. It read around about 5 to 10 pounds less than what its now reading fitted and plugged into the 100psi sensor it came with now attached to sandwich plate.
    This either suggests that a reading from the sensor on top of motor is slightly out or that its not particularly made to read pressure ( I wouldn't know)
    As Chrisvyss says, you get a check engine warning as soon as you unplug the sensor reader from factory sensor. I was going to tap into the wiring on the original sensor but have read that you get inaccurate readings doing that and wasn't keen to chop up wires.
    Best option for me was the sandwich plate as I can remove it and all wiring if I decide to sell car and keep gauges and not have to do anything but undo everything.
    I'd be interested to hear how other readers fitted their oil pressure gauges.
    Black VY
    Mar 2009
    MELBOURNE
    ^^^^^^^ I did it the same way with the speco sandwich plate. the only reason i did this is that i saw my brother have nothing but problems with fitting the genuine hsv gauges.
    alternatively you could buy these. Aeroforce Technology Inc | Products - Interceptor they plug straight into the obd2 port
    2008 VE 6lt SS Ute
    May 2011
    hmmm i like the sound of how you did it, did u get the parts off ebay? i can find a sandwitch plate but not the rest. i mate of mine suggested cutting into the sensor wires ontop of the engine like you said but im not to keen on that idea either.
    Black VY
    Mar 2009
    MELBOURNE
    Quote Originally Posted by WELSHH View Post
    what other parts cant you find, the sandwich plate is pretty much all you need besides the gauge[which come with the appropriate fittings and lines]
    VY SS UTE
    Jan 2011
    SE QLD
    None of the parts from ebay besides the gauges.
    I ordered the sandwich plate through autobarn, fitted it all myself, wiring that came with gauges only just made it to the sandwich plate, not sure how long your wiring is but make sure you have enough length of wiring and use thread sealant when inserting the pressure sensor if you plan to do it that way.
    Fill us in with what you have, do you have the gauges and wiring or just the gauges?
    VY SS UTE
    Jan 2011
    SE QLD
    Quote Originally Posted by rx2_freak View Post
    Sandwich plate is the easiest way for sure RX2 freak, those areoforce look good, but I don't like the colours they come in and I prefer the dial gauges over digital.
    2008 VE 6lt SS Ute
    May 2011
    all i have is literally the guages, i bought the car and they wernt hooked up (oil pressure and voltage) so besides the HSV guages i have nothing, no wiring, no sender etc
    2008 VE 6lt SS Ute
    May 2011
    Black VY
    Mar 2009
    MELBOURNE
    the standard HSV gauges are rubbish, as above i have seen people have dramas fitting them. To install them you need to go to holden and get the loom and all wiring from them[big $$$$$]. Do you have the genuine hsv gauge pod.
    Your best bet would be to buy an aftermarket electric oil pressure gauge and a sandwich plate, and a volt gauge. They are super easy to fit can be done in probably half a day if you have basic knowledge[gauges have instructions included]
  15. #15
    2008 VE 6lt SS Ute
    May 2011
    yea i have the genuine hsv guage pod, ive had a bit of a look at the back of these and they do look like a pain just by the looking at them, i have been considering swaping to elctric guages, just cant find one that really catches me.
  16. #16
    Black VY
    Mar 2009
    MELBOURNE
  17. #17
    2008 VE 6lt SS Ute
    May 2011
  18. #18
    VY SS UTE
    Jan 2011
    SE QLD
    What colour is your dash, I found these after a long search to match up with my dash
    Both Gauges are full sweep... delivered $280, includes all looms, oil pressure sensor and instructions. Oil pressure gauge includes adjustable low and high pressure warning light.
    Better than HSV IMO, only regret is not specifying a green backlight.
    [/URL]
  19. #19
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    Quote Originally Posted by SS Manual View Post
    [/URL]
    is that the hsv cover?? how much did that set you back...
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
  20. #20
    VY SS UTE
    Jan 2011
    SE QLD
    No, not sure who makes them but they're a VZ style for the VY, don't think HSV made them that shape for the VY?, this one cost about $150ish on ebay. It's good quality plastic and doesn't have any issues in the sun all day like others I've heard about.
  21. #21
    Black VY
    Mar 2009
    MELBOURNE
    I used to have one of those cheap vz style gauge pods, had nothing but trouble didn't fit properly from day one. Just bought a hsv one and pit two autometer gauges in it, I need to change them as they don't match my new cluster or LEDs.
    Ss where did you get your gauges from.
    Sent from my iPhone using Tapatalk
  22. #22
    2008 VE 6lt SS Ute
    May 2011
    they are exactly what i want ss!!!! my cluster and all the trim and stitching my my car is green, (green ss with leather) so i would love thoes ones with a green backing! nice deal too, but i havent seen them on ebay?
    dont mind the pod either, mines the usual vy one i think.
  23. #23
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    i had a look on ebay and they are way more expensive then 150...the only ones for 150 are like those
    ss induction ones and they dont look to good
    My Ride
  24. #24
    2008 VE 6lt SS Ute
    May 2011
  25. #25
    VY SS UTE
    Jan 2011
    SE QLD
    Yes, none for a buy it now price, however, occasionally the seller auctions them, selling for $198 at the moment at buy it now price.
  1. Oil pressure gauge
    By VSteve in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2010, 12:25 AM
  2. Oil Pressure Gauge
    By My Car in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-01-2009, 10:15 AM
  3. Oil Pressure Gauge
    Last Post: 22-11-2008, 12:48 PM
  4. Oil pressure gauge
    By sen8or in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2007, 01:11 PM
  5. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
