Tech2 OBD II Software
adamdunford86
Perth, WA
2002 VY Commodore 3.8 (Dual Fuel)
Hi Guys
I want to active the police mode on my 2002 VY commodore. Plus look up any error codes and have a general nose round the setup of the ECU
I have the Tech2 OBD II cable for my computer, i have located the ECU socket under the steering wheel
But not sure what software to download and use to do this? I have had a look at EFILive v4 but couldnt get it going.
Any ideas would be great as i dont really want to go down and hassle the dealer.
Thanks
Adam
Fletch_QLD
Brisbane Bayside
VU II SS
V6 needs OBD I (ALDL) not OBD II I thought ?
brodster
Frankston
vn hsv wagon
Mate waste of time playing with comp as it dont make it go any faster unless you work engine,do an engine conversion to a supercharged v6
Fletch_QLD
Brisbane Bayside
VU II SS
It's not about making it go harder, or sounding beast, it's about poking around.
PRAVX II S
Australia
Commodore
Yes you are right mate.
From vz onwards its protocol is OBD II.
To the op you need to make the OBD cable it uses OBD II connector but talks OBD I.
adamdunford86
Perth, WA
Hi guys
Thanks for the reply, im not interested in making the car faster, but enabling the police mode to get a permanent digital speedo, and also looking at any error codes the car has or may get in the future, will also be interesting to have a look at the other settings in there.
So my Tech2 OBDII cable is no good for the VY 02?
Thanks
Adam
Fletch_QLD
Brisbane Bayside
VU II SS
Hi guys
That is correct - (no good for VY V6). Also, I don't think police mode is DIY possible, consumer OBD tools can only read info.
one_and_only2004
Turbo L98 FTW
Regional NSW Australia
Z Series Thunder Utility - Turbo
Yep, you either need to see Holden and get them to enable police mode, or phreddy from ASR can do it too. My Holden dealer did it for free.
chargedvx6
VY SII HBD Calais L67
Hi guys
Thanks
Adam
The OBDII plug is the same as an OBDI plug (what your car needs), it's just the language/ speed the tech talks to your car in is different.
Go with the cable and find the correct software to talk 8192BAUD. Send me a pm and I'll link you up
