Results 1 to 6 of 6
Thread: question about 20"s
    VY Berlina
    May 2011
    Central Coast
    Question question about 20"s
    hi just a question because i almost got them today,
    what do i need/should do, to have a set of 20's on my car? ive got a vy berlina (completely stock) and im tossing up between 18's 19's and 20's
    suggestions please
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    VY Berlina
    May 2011
    Central Coast
    VY Berlina
    May 2011
    Central Coast
    did read over, however doesnt really answer anything about what needs to get done to the car to get it safe/responisable
    VY S/II S Pack
    Apr 2011
    Your local tyre place should be able to offer you the needed advice.
    Laws differ between states, but I am under the impression that all states now have the rule of maximum increase of rolling diameter by 15mm. This simply means you will have to get lower profile tyres in order for it to be legal, and your local tyre place should give you the correct advice as far as this goes.
    The other problem you may encounter is your tyres rubbing on the insides of your guards. This is a simple job for a panel beater who use a heat gun (so the paint doesn't crack) and a mallet to "roll" your guards. Normally it's only required for the rear guards, costs around $50 too $100 per guard.
    Other than that, you don't really need to do anything to prepare for 20's, just prepare yourself for war vs. potholes.
    VY Berlina
    May 2011
    Central Coast
    ok thank you for your help, that answers a few questions. i should just have a chat with a tyre shop
  1. Question about 15 x 7 steel wheels "interceptors"
    By bj42turbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2011, 01:55 PM
  2. spring "strut top" question
    By kuzman89 in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-05-2011, 09:10 AM
  3. " B " cast heads question
    By dave-the-sparky in forum V8 Development and Modification
    Last Post: 06-11-2009, 08:18 AM
  4. A question for 202 owners "ECO"
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-01-2007, 08:38 AM
  5. quick question to mods "Burnout comp"
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-05-2006, 06:03 PM
