Results 1 to 15 of 15
Thread: How to Wire up VZ Interior Sunglasses Light to a VY Centre dome light connection
    VY SS
    Jul 2011
    Melbourne VIC
    Default How to Wire up VZ Interior Sunglasses Light to a VY Centre dome light connection
    Hi all
    I have a VY SS Series 1 which came with the full black leather interior except the roof lining & pillars. I recently replaced the roof lining and all pillars to the black ones out of the VZ SS/HSV and it looks 10 times better.
    Only problem now is my existing roof lining had the VT style interior dome light in the middle of the roof which had a connector going into it consisting of four little wires into 1 plug. The wire colors are as follows:
    Black
    Yellow with a stripe of green
    Orange with a stripe of black
    White with a stripe of green
    I cut them off the plug as the new VZ sunnies holder light has a 6 pin plug and it will not fit into it. The VZ sunnies light has the same colors as mine sticking out of the plug PLUS an extra two colors (purple and flat orange from memory) so what i did was connect the four colors to the same wires on the vz sunnies one and tried to power it on and nothing happened.
    I have tried looking for guides on how to get this working and have found a few on here but they all involve KEEPING THE ORIGINAL light wired, and wiring the VZ one into the roof so there is two lights. I do not want that as my whole lining is off the VZ so i just want my wires to connect up to the VZ sunnies one and have that be my main light but i am having no success.
    Has anybody done this before successfully? If so can you please tell me where do i wire up the existing four wires that i have hanging out of my roof now onto the vz sunnies light to get it to work and i really dont want to have to pay an auto elec 100$ for taping together 4 wires...
    heyitsEnricoPallazzo's Avatar
    heyitsEnricoPallazzo is offline Big block Alloytec
    VZ A4 Saloon
    Nov 2010
    A schematic might help.
    Attached Thumbnails Attached Thumbnails How to Wire up VZ Interior Sunglasses Light to a VY Centre dome light connection-img003-copy.jpg
    VY SS
    Jul 2011
    Melbourne VIC
    Not really, as that shows bcm connections, i already have the wires i need hanging out of my roof - i just need to know where to attach them to on the VZ Sunnies Light... this has to have been done before...
    BakeTheTank's Avatar
    BakeTheTank is offline Phreddy-ed UP!
    VY S Series II
    Jan 2011
    Riverina NSW
    Hey mate, sorry to be off topic, but do you have pics of the new roof lining? i was looking at doing it also!
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Use a multimeter/test light to check your existing wires. Black will be earth, the others can only be +batt or +acc I woulda thought?
    Anyways, I can't see a little trial and error hurting, and imagine that if you wired it up so that same wires match up - old harness to new plug, you'll be fine. The 2 extra wires will be to feed the rear passenger l;ights so I would think can be safely ignored ?
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    VY SS
    Jul 2011
    Melbourne VIC
    VZ A4 Saloon
    Nov 2010
    It should work if you do this:
    white/green(wg) to yellow/blue (yl).
    orange/black(ob) to orange/black(right side).
    black(bl) to purple(p) & black(bl).
    yellow/blue(yl) to orange/black(left side) & white/green(wg).
    Notes,
    All colours in bold are existing vehicle wires. Balance are VZ interior lighting connector.
    You will need to find the correct L&R orange/brown wires yourself by refering to the schematic below.
    Pull the interior illumination fuse before starting work.
    No responsibility accepted on my part for any damage.
    Good luck!
    VY SS
    Jul 2011
    Melbourne VIC
    Your a champion my friend this is exactly what i was looking for.. I am going to try this first chance i get. I thought by connecting same color wires it should have worked but obviously that was not the case.. especially when i seen the purple and second orange wire hanging on the connector.. i just thought they were not to be utilized as i didnt have them sticking out of my roof.
    Will try and let you know how i go.
    VZ A4 Saloon
    Nov 2010
    Default Even easier
    To save some rootin' around. I have done the work for you.
    See pic.
    RH orange/black wire is #6.
    LH orange/black wire is #3
    Attached Thumbnails Attached Thumbnails How to Wire up VZ Interior Sunglasses Light to a VY Centre dome light connection-photo0217.jpg
    VY SS
    Jul 2011
    Melbourne VIC
    Quote Originally Posted by heyitsEnricoPallazzo View Post
    See pic.
    RH orange/brown wire is #6.
    LH orange/brown wire is #3
    Your a champion mate many thanks.
    I am going to do this Saturday (would have done it earlier but i work till dark)
    I have one question though, where you have listed the following:
    orange/brown(ob) to orange/brown(right side).
    black/white(bl) to purple(p) & black/white(bl).
    yellow/blue(yl) to orange/brown(left side) & white/green(wg).
    I do not have a black/white lead coming out of my roof - the lead i have coming out seems to be fully black.. is it the same thing?
    VZ A4 Saloon
    Nov 2010
    VY SS
    Jul 2011
    Melbourne VIC
    Worked like champ mate, owe you heaps for that!
    I'll try and get pics up of the finished project by tommorow!
    VZ A4 Saloon
    Nov 2010
    VY SS
    Jul 2011
    Melbourne VIC
    Just an update people...
    Went with for a drive with a few of the boys at night, and as they opened the back doors they mentioned about the darkness in the back seats... then they looked up at the little lights above the back seat doors and said, hey why dont they work?
    I totally forgot all about them lights, but as i now remember it, they are wired to the new roof lining and the plug that came out of it - which has now been discarded as i used my wires which are on my car
    Any experts on how to wire these to work without ripping the lining out again? Appreciate your comments especially 'enrico pallazo'.
    VZ A4 Saloon
    Nov 2010
    For the rears there are 3 wires on each side. Black, white/green & orange/brown. They should connect directly to the same colours as the existing factory interior illumination loom eg. black to black etc. with the yellow/blue wire not connected to the rears.
    As to connecting them without ripping out the lining again, I can't say.
    Where's the bloody pic?
  1. Interior Calais dome light?
    By Mayte123 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-06-2010, 03:08 AM
  2. VY/VZ Sunglasses/Interior Light into VR/VS?
    By seraphic06 in forum Electrical Wiring / Questions
    Last Post: 02-11-2009, 12:41 AM
  3. centre interior light
    By dakman in forum VE Holden Commodore (2006 - ?)
    Last Post: 05-10-2009, 07:08 PM
  4. Interior Dome Light
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2009, 12:32 PM
  5. VY Interior Light/Sunglasses Holder into VT
    By Toeludeu in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2009, 08:35 PM
