Results 1 to 10 of 10
Thread: Squeaking Sound when driving.
    VY 25th Anniversary Commodore
    Jul 2011
    Newcastle
    Question Squeaking Sound when driving.
    I recently purchased a 2003 VY 25th Anniversary Commodore. It has about 73, 000 klms on it. About 2 weeks after I bought it, it started to make a squeaking type of sound. It doesnt happen when braking, only while driving and the noise seems to get faster as the wheels rotate faster . I cant seem to find which side its coming from either as it happens at random times. Its not the fan belt. Its quite frustrating. Ive taken it to my mechanic and he took it for a drive and of course it didnt squeak. Does anyone have any ideas or have had something similar happen to them ? Before I take it somewhere and they tell me a load of bull and sell me something I dont need because Im a woman and dont know any better...Id really appreciate some advice
    Ignited-SV6's Avatar
    Ignited-SV6 is offline Sleek and Class
    VY Berlina
    Jun 2010
    A squeak could be anything...
    Seeing as you said it's more noticable as the wheels rotate faster, you'd best be off taking it to a wheel specialist place like Beurepairs or brakes plus, somewhere like that.
    Unless it's affecting the cars mechanics, I can't imagine it being anything serious. More so seeing that it comes n goes.
    Don't worry about it costing you too much.
    My Ride
    http://forums.justcommodores.com.au/...a-ss-rims.html
    Next mods: Lowering, 4 Channel Amp and eventually 19's
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    sounds like the handbrake not disengaging properly,was a common problem in the vy's. my vy does it also.
    in the vz,they fixed it by fiting an extra spring or something which helped push the handbrake off the back wheels better...
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    As above, the handbrake can make like a chuffing/scraping/grinding sound. Usually sounds a bit like a steam train. It comes from the back wheels. Generally you will only hear it with the window down when driving past a building/fence that will reflect the sound back. It's just an annoyance, doesn't effect anything negatively. There's a 'anti-scrape' kit to fix it.
    How do you know it's not the fan belt? Have you changed it? Reason i ask is that mine started making a squeek-squeek-squeek noise but only under light throttle and light load. The frequency of the squeeks didn't speed up much with engine rpm either.
    At idle, coasting, braking, wide open throttle and revving it in neutral it didn't make any noise. It started doing it only on really cold mornings, then progressed to the point that it would do it in any weather conditions.
    Vy S s2
    Oct 2010
    have the same problem mine comes from the brake everytime i say hit a bump it squeaks its rlly annoying
    vy berlina 5.7
    Mar 2010
    QLD
    Jul 2011
    Newcastle
    Thanks all above for your replies. I am booked in Thursday and a tyre/wheel place is going to look over the car for me to see if they can sort it before I get some rims put on. I will look into the above mentioned issues and see if they could be the cause. Much appreciated Will update soon. Cheers.
    Jul 2011
    Newcastle
    Default Hmm new development
    I backed out my driveway this morning...its not a steep driveway. I heard the same squeak...with a bit of grinding this time. I know theres some time before brake pads need replacing, but when I get car looked at tomorrow I will let them know.
    I will make sure they check the handbrake as well.
    VY 3.8L Executive with Clubby Kit. Ex Marked Cop C
    Mar 2011
    Auckland, New Zealand
    Check the front right caliper area and compare it to the front left. Mine had a clip missing once that caused this.
    undersuspicion is offline Now That's How We Roll!
    Vy SV8 Series 2
    Aug 2010
    has anyone mentioned the main drive belt? Could be that.
    don't take this wrong or anything but ARE YOU ####ED IN THE HEAD????
    Reaper
  1. squeaking sound when turning left
    By LthlThrt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-07-2010, 12:26 AM
  2. Squeaking sound on start up
    By HyperYellowVXSS in forum General
    Last Post: 11-10-2009, 05:02 PM
  3. rattling squeaking sound
    By vn88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-01-2009, 09:02 PM
  4. Squeaking windows - driving me mad
    By Laila in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-06-2006, 04:18 PM
  5. Squeaking rear right wheel while driving
    By willy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2006, 09:17 PM
