Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Thread: Oil in radiator???
    Vy Exec
    Feb 2009
    Default Oil in radiator???
    Hi people I have what look's to be oil in the radiator mixed with the coolant which forms a brown colour.It's not the head gasket did a check and not drinking oil and did a pressure cooling test and all is fine. Temperature sit's on normal.Somebody told me could be transmissin fluid as it passes through the radiator.I dont know if he was talking about the trans cooler etc,but he said a part in the radiator is gone so need a reco radiator.He also said it is common on Vy model.Thoughts ???.
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
    yep more common on the ford ba, a radiator has a trans cooler inside it if your lucky you will just have oil in your water, replace radiator with a stainless steel core, and all will be good, but if you have water in ur trans ur up for a full rebuild and a new radiator clutches and bands dont like getting water in them, as do ur needle roller bearings.
    so i suggest you check ur trans oil, or if your not sure take it to a trans shop maybe get a trans service and go from there, but as said above you may be lucky and only have oil in your water.
    Dec 2009
    I had this problem with my VY. It turned out the inlet manifold bolts had come loose on the cylinder heads. I tightened them up and it's all good for now, just a bit of residual oil but that can be removed over a few days.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Also the silly pellets they put in can cause a 'brown sludge' to form. I would do a full cooling system flush before spending any more dollars than just buying new coolant.
    VY S V6 Ute Series II 2004
    Nov 2009
    The pellets (finely ground walnut shells?) holden advise adding to the coolant do make it go a brownish green colour. Some commodore owners also mistake it for rust in the system.
    Vy Exec
    Feb 2009
    Thanks for the reply guys.I did a trans service not so long ago and all is fine they said.I have flushed it twice with new coolant and same crap appears so I dont think it's the pellets. How does the trans cooler leak?So what would a new radiator cost me fitted?Thanks
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by SavVYute View Post
    Yep and I have never and will never use 'em.
    VX acclaim S2
    Oct 2009
    You have side tanks on ur radiator that ur trans cooling lines will go into,my guess is that ur seal or core has broken, rusted through, causing trans fluid in the radiator and through ur cooling system, I recently did 2 radiators on a VX commodore, take about an hour including a coolant flush and can be done on the floor, quiet easy for a DIY, and eBay radiators in ur state, ring them n pick it up, should coast u bout 120. Shoot me up if ur keen to no more on DIY
    Aug 2010
    Girrawheen
    Replace the radiator is a diy job. Just make sure u bleed the system afterwards and have something to block the cooler lines with when u disconnect them. You will lose sum trans fluid
    Sent from my Samsung Galaxy using Tapatalk
    Vy Exec
    Feb 2009
    Quote Originally Posted by kizza50 View Post
    Thanks for the replys im in victoria in the western suburbs.
    03 VY_S
    Jan 2008
    this happended to me recently, mechanic said my inlet manifold gaskets needed replacing as they were leaking, got the job done, no problems for over 4 months now
    Vy Exec
    Feb 2009
    Going to get this problem fixed this week guys.How do I know if it's the radiator or inlet manifold gaskets that need to be done ??? dont want to replace not the existing problem.Can the mechanics test out for either one.Thanks guys.
    Vy Exec
    Feb 2009
    Quote Originally Posted by guyman View Post
    what did that cost you??
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    If its the radiator the oil will be pink or reddish colour.
    Silver Certified.
  15. #15
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by Tiger28 View Post
    Just do both. They are both going to need to be done eventually. If the radiator has some k's on it (100,000+) then it's going to be ready for the bin soon anyway.
    I had a slow coolant leak, no idea what was causing it, replaced radiator, inlet gaskets, thermostat and heater tap all at the same time. Problem solved!
    Quote Originally Posted by RiCeY View Post
    And it'll float. If the gunk in the radiator is suspended in the coolant it's from the pellets, or from the coolant gunking up due to a leak.
  16. #16
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    Quote Originally Posted by TMM View Post
    Have to disagree there, my radiator has clocked 170,000kms still going strong
    Silver Certified.
  17. #17
    2008 VE 6lt SS Ute
    May 2011
    agreed, mines done 150,000 and hasn't missed a beat.
  18. #18
    VS Stato l67
    Mar 2009
    Melb
    My original radiator let go at 230k
  19. #19
    Vy Exec
    Feb 2009
    Took the car in to the mechanic and he had a good look at it.Did a pressure test cooling system check all was fine ,checked trans cooler and and trans oil and engine oil all was fine.He said oily brown residue on overflow dipstick and radiator cap is from the pellets holden put in and nothing is wrong with the car.
  20. #20
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    If it was the cooling system pellets causing the "OILY" contamination then this should show up on every car that has the pellets added. It does not because it's a faulty diagnosis.
    I have NEVER had any sign of brown or other contaminant in my cooling system in my VY and I added the pellets myself with the last cooling system flush I carried out. 20 months later the coolant is very clean. There is no sign of any contaminent whatsoever on the coolant dipstick, in the radiator or on the radiator cap. The coolant is very, very clean. This is how it has always been on my vehicle and is how it should be.
    The "oily brown" residue you refer to is not due to the cooling system pellets as the mechanic maintains. For starters the formulation of the pellets is completely non-oily. Buy some, crush one up and add it to the correct spec coolant mix and you will see that there is absolutely no "oily" substance formed in the sample.
    In any event you have indicated above that you have flushed your radiator twice and the "oily" contamination re-appears each time. It will until the real problem is addressed.
    Oil obviously floats and, as you have found, if an oily substance has found it's way into the coolant some will eventually attach itself to the radiator cap, the top of the inside of the radiator and the coolant dipstck.
  21. #21
    Chevrolet Lumina Coupe S (Monaro CV6)
    Feb 2011
    Abu Dhabi
    I wouldn't be surprised if it's a problem with the lower inlet manifold gasket - a known weakness, after all.
  22. #22
    Vy Exec
    Feb 2009
    Quote Originally Posted by Richard Moss View Post
    So what a the tell signs for this problem ???
  23. #23
    Vy Exec
    Feb 2009
    Quote Originally Posted by Sean880 View Post
    Thanks for the feedback I'm just going on what he told me.He checked the car out properly as I said trans cooler,oil etc.
  24. #24
    VR commodore
    Aug 2011
    Pakanham victoria
    how u going mate i work on cars all the time and this is a common fault with the vs to vy engines, its the inlet manafold, it is more common on the super charged vx commo's but it does do it on the rest of them, the good thing is its not a hard problem to fix
  25. #25
    Vy Exec
    Feb 2009
    Quote Originally Posted by smudgy View Post
    Thanks mate for that.So how can I tell thats the problem ?? as I went to another 2 mechanics today and told me the radiator might be gone.I dont want to change things thats not the issue.What's it worth to fix?.
  1. Rb25/30 Radiator hose for vl radiator.
    By vl_2010 in forum Straight 6 Development And Modification
    Last Post: 23-06-2011, 11:46 PM
  2. should external trans radiator be inline with radiator compartment
    By ybl8te in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-10-2010, 10:50 AM
  3. changing VN S1 radiator to VN S2 radiator
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2009, 06:30 PM
  4. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
