Results 1 to 3 of 3
Thread: vy drive shaft bearing noise? Help please!
    vnss
    Jan 2007
    wyndhamvale vic
    Default vy drive shaft bearing noise? Help please!
    Hi guys. Not to sure what this is but when i drive there is like a squeeling squeeking noise coming from under my car that is relevent to the speed of the car. That is it( the noise) gets faster the faster I go. Dont know whether its drive shaft unis, of centre bearing or wheel bearings or gear box..... Any help would be great thanks.......It sounds like a dry bearing noise
    5.7L VY SS M6
    Feb 2009
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    I guess this reply is more for the thread digger than the OP.
    I just got quoted $515 by holden to replace front tail shaft coupling and trans ext housing seal. I have noticed the noise described by the op for the last 4months or so, and lately I feel a bit of a wobble being produced.
    The new tailshaft coupling is close to $200. I haven't priced the seal. The job is apparently quite easy if you can get enough room under the car to work.
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
  1. Drive shaft noise
    By banndit in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2010, 10:20 PM
  2. Center drive shaft bearing
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2010, 09:09 AM
  3. Noise from drive shaft manual VN
    By VnNz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-07-2009, 08:16 PM
  4. balance shaft bearing noise
    By ryan1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 06:29 PM
  5. centre bearing drive shaft
    By vncruzr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 01:54 PM
