Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By GEN3RATD
Thread: my first car
    vy commodore
    Jul 2011
    toowoomba
    Default my first car
    how can i tell if it is a alloy tech or eco tech? and what kind of exaust would give it a deep tone?
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    vs to vy have ecotec, vz and up have the alloytec
    Yours being a vy would be the 3.8 ecotec
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    vy commodore
    Jul 2011
    toowoomba
    alloytech are 190 kw? and ecotech are 152 kw. so ive been told. there must be a simple way to find out by looking in the engine bay?
    vy commodore
    Jul 2011
    toowoomba
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by brentbrah View Post
    the vzs i think have the 170 or 175 and the sv6 vz have the 190kw, vs - vt ecotec has 147kw ecotec, vy and that have the 152kw ecotec
    wiki has all the info
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    vy commodore
    Jul 2011
    toowoomba
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    '06 vz sv6
    May 2011
    coffs harbour
    Cai - $450/$600
    catback - $300/$600
    ecu tune - $550/$900
    hi flow cats - $300+
    headers/extractors - $450+
    otr - $500/$650
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Alloytec
    Ecotec
    In terms of performance. Save your pennies and upgrade your rockers to a higher ratio such as 1.9:1 or higher. Mace Engineering or Yella Terra supply these upgrades for about $600 to suit the VY. CAI on a V6 I wouldn't bother. Money better spent elsewhere. This goes too with hi-flow cats. Extractors will be beneficial but not really a priority until you are producing more power at the engine. I'm not sure why an OTR and a CAI were recommended by the same person or why OTR was even suggested seeing as OTR is short for OTRCAI which stands for Over The Radiator Cold Air Intake, an item not applicable to the ecotec engine.
    I would recommend doing these mods in this order:
    Single 2.5" catback - $200+
    High Ratio Roller Rockers - $600
    Mace manifold Insulator - $150-$220
    Mace Plenum Spacer - $150-$220
    This will cost around the $1100-$1500 mark and will increase overall power by maybe 15~rwkw and improve drivability significantly. Hope this helps a bit.
    Don't go nuts with a V6 though unless you fully plan on going for big power later such as FI. Even then I'd personally save my money and buy a V8 when I could. I'm currently on my greens and am planning on buying myself a V8 for my 21st.
    A Commodore is a passion. Anything else is just a car
    '96 VS Executive 3.8L
    Apr 2010
    Bacchus Marsh VIC
    $600 camwould get you more alone than all the above mods, and eve more with them
    FIRST CAR
    any fat chicks in the back? that usually causes lack of power and bad fuel economy
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    To support a cam upgrade you need a fatter exhaust, possibly greater intake and a tune making this a much more expensive venture. However, you are right when you say it will get you more power.
    Apr 2010
    Bacchus Marsh VIC
    Quote Originally Posted by DUK13Y View Post
    Yer I agree, glad I didn't get flamed. But all the other mods by them selfs will just turn the cam into a bottle neck so you may as well get the cam first coz you'll start out with more power and get the other stuff later. If he spends a few hundred on the intake and what not he'll be disappointed
    FIRST CAR
  15. #15
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    what are a few simple things i can do to up the power/kw ?
    searching will double your killerwasps
    If it isnt tuckin, it must be suckin
  16. #16
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    Quote Originally Posted by General Xander View Post
    Yeah sorta. The way I see it is it's always best to do your supporting mods first so when you get the cam, and tune to suit, the tune will be perfect. If you do cam+tune first, the car won't really like it as it changes the way it runs, requiring the larger exhaust, etc, rather than it being an option. Also when the supporting mods are installed after the cam, you will need to retune, adding another $800~ to the final price.
  17. #17
    Apr 2010
    Bacchus Marsh VIC
    Yer I get ya, good point, I guess I'm lucky getting tunes basicly for free, i guess the best option would be to do it all at once
    FIRST CAR
  18. #18
    2003 VY S II
    Jun 2011
    Bulleen
    I have a vy v6 and I will be doing high ratio rockers and a lukey cat back exhaust. What benefits would I see from these? Also to the op, don't spend alot on mods for an n/a v6, unless your looking at major aftermarket mods like super/turbo charging stick with simple, cheap ish mods to keep you happy with your car which its what I'm doing :-)
    Sent from my Samsung Galaxy S2 using Tapatalk
  19. #19
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    Quote Originally Posted by revhead2011 View Post
    Based on your own words.
    Ditch the High ratio rockers and just go the lukey cat back.
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
  20. #20
    Apr 2010
    Bacchus Marsh VIC
    Quote Originally Posted by some_guy View Post
    Look at it this way. Unless you'll need a tune after the mod, there's going to be bugger all power increase. save, get hr rockers, a cam, mabe a stroker, and whatever exhaust you wanna do, put it all on at once, tune, then you'll get a decent increase. You shouldn't need a bigger throttle body or filter unless you start porting the head.
    I've seen engines on the dyne with stock filters absolutly filled with crap, and they still make full power. The stock filters are good enough until you do some real mods like boost or a full induction-exhaust set up
    Same with the throttle body, if holden found that the v8 throttle body was that much better than the 6, they would've put it on
    Sent from my HTC Tattoo using Tapatalk
    FIRST CAR
