Results 1 to 5 of 5
Thread: vt to vy delima
    300kw 2000 vt ss, 2004 vy ss
    Jul 2011
    southland new zealand
    Default vt to vy delima
    I have a 2000 vt ss that is poking out 302kw at the back wheels. the car recently had an arguement with a pole and lost. the motor has had a lot of money spent on it and has only done 12,000 ks and would like put this engine and my shift kitted trans in to a 2004 vy ss rather then having to go through the rebuild process again. if any knows if this is an easy task ie; are the computers, mounts, wiring looms etc all the same or similar. or is it even practical?
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    dont think it can leagally be done.. can put older engine in newer vehicle... unless you engineer it.. not sure about nz.. sot sure about any of it really
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    I too have heard that you cant stick an older engine into a newer car. However, might be worth considering the engineers cert seeing as you've obviously spent a lot of money on the engine.
    A Commodore is a passion. Anything else is just a car
    Jul 2011
    the certifacation is not an issue over here as the motors are both ls1's.
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Everything is pretty much identical as far as I know. It's only in the VZ that they started changing gearboxes and stuff.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
