Results 1 to 8 of 8
Thread: VY Power Steering Cooler
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Default VY Power Steering Cooler
    Hey Guys.
    VY commodore wagon V6 Auto
    Appears the Front power steering cooler line in the front of the radiator has rusted like mad and think thats where all my power steering oil is going, Its everywhere in the front of the radiator and my level is dropping very quick. Its not the rack, and not the pump i just replaced that 2 months ago, was fine until about this week when the level has dropped. Any ideas what to replace that hose with or where i can get a replacement online ?
    Also have found coolant all along the bottom of my radiator, not sure if its just coolant left over from a flush when i did my power steering pump or what but that was 2 months ago.
    Any help would be great. im really hating cars at the moment lol
    http://www.ebay.com.au/itm/POWER-STE...#ht_1493wt_907
    Maybe something like that to replace the rusted cool pipe
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    Suggest you go local and buy from PWR(PWR Aluminium Radiators, Intercoolers & Oil Coolers)... however, Unless you are circuit racing the std cooler is more than enough, so just go to a wrecker and get one.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Ok Cheers mate.
    Ill Give holden a call monday and see if i can still get the hose.
    If not ill try the wreckers and see what they have.
    Also the radiator has shit its self too the side tank has let go.
    So new Radiator, Cooler hose and replace the water pump while im at it. maybe even the heater tap if its crap
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Rang Holden they stock the cooler pipe, Apparently its a common issue with them rusting out. $60 pretty cheap
    Installed new radiator and water pump yesterday. All Good :-)
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Quote Originally Posted by edals View Post
    That's not too bad a price for the pipe, I would have guessed it'd be more than that.
    I also would have thought they would have the decency to make them out of aluminium. Will have to check mine, live near the beach.
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    This is what mine looks like, and yes the beach is at the end of my street and previous owner lived next to it also.
    Chevrolet Lumina Coupe S (Monaro CV6)
    Feb 2011
    Abu Dhabi
    In an emergency, for a "get you home" type fix, you should be able to cut out the rusty section and replace it with some flexible hose (heater hoses for example).
    edals's Avatar
    Sep 2008
    QLD/NSW Boardish
    Fitted new cooler today, Easyish Job. Biggest pain trying to get the pipes between the radiator and bottom bar. Be Much easier if you removed the front bumper but i just kept going at it till i finally got it it. Hope my Fluid will now stop dropping. Just 3 Screws and 2 hose clamps, be sure to have 2 bolts to block the 2 rubber hoses, Once new one fitted, Put the Return hose on first, allow it to fill the new pipe while toping it up, then stick the other hose on to avoid air in the system
  1. [Ecotec] Power steering cooler, need pointers
    By GTP 85 in forum V6 Development And Modification
    Last Post: 04-03-2011, 01:46 PM
  2. Power Steering Cooler?
    By seraphic06 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2009, 10:11 AM
  3. Power steering cooler
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2007, 07:50 AM
  4. VK Power Steering Cooler..??
    By 308vkcalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-10-2006, 09:36 PM
  5. Power Steering Cooler
    Last Post: 03-07-2006, 07:50 PM
