Results 1 to 4 of 4
Thread: ls1 engine missing on idle
    vy one tonner v8
    Apr 2011
    gold coast
    Default ls1 engine missing on idle
    hi i have a vy 03 one tonner with the ls1 and just recently its been missing a bit on idle and hesitates and jumps when u accelarate, i asked at auto barn if it could be the fuel filter or leads, but if it was the fuel filter i would get a flat spot on hard acceration wouldnt i and serging on the highway i dont get either, so he thought i might be a coil pack maybe! any thoughts would be great help. thanks,
    i did purchase a new fuel filter any way but i cant find the fuel filter on my ute i look all over near the tank and its not there. its a one tonner if any one has one could u please help to locate it for me.
    thanks
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    I know on the styleside utes the fuel filter is right behind the back wheel under tray on the drivers side. Check your plug leads are pushed into the coils right, one of my leads keeps popping off the coils and makes it run like poo
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VX Senator 300
    Oct 2005
    The 'gul, Vic.
    Check oxygen sensors - my bet is that they will be the problem. Otherwise, ensure all leads / plugs are properly fitted and that you don't have any fuel / air filter blockages. See if you can get it to Holden, or an Lxx tuning shop and they can scan it for you.
    cheers
    Senator 300 - the CLASSY C4B!
    LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
    vy one tonner v8
    Apr 2011
    gold coast
    hey thanks for advise, i checked the leads and one broken in half so i replaced all leads they were wrecked, i still need to know were the fuel filter is i got a car manual and it shows it near fuel tank near the black charcol canister but my filter is not next to it, so any on who has a one tonner please advise.
    thanks
  1. VP V6 missing at idle and under load
    By vp-s in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2011, 08:22 PM
  2. Vt 5.0 idle problems and missing also engine light and oil light come on
    By vtss5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2011, 07:32 PM
  3. VR V6 missing at idle
    By -=$natch=- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2010, 05:37 PM
  4. missing just above idle
    By bazza250 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-05-2008, 03:36 PM
  5. missing on idle
    By shindiger in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2005, 10:27 PM
