Results 1 to 4 of 4
Thread: How To install new handbrake lever
    Ignited-SV6's Avatar
    Ignited-SV6 is offline Sleek and Class
    VY Berlina
    Jun 2010
    Default How To install new handbrake lever
    I wasn't sure if I should post this here or in the How To's page but I did a search on Google and the forum and couldn't find anything.
    Just got a Calais handbrake and not sure how to install it. Any help or any links to share so I can get this done?
    Thanks in advance.
    My Ride
    http://forums.justcommodores.com.au/...a-ss-rims.html
    Next mods: Lowering, 4 Channel Amp and eventually 19's
    VY Berlina
    Jun 2010
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Hi Ignited
    The handbrake is fixed into place with two bolts at the bottom, under the rubber sleeve..
    1. Slide the driver's seat right back.
    2. Lift the rubber sleever, take note of the position of the adjusting nut on the brake adjuster and undo the adjusting nut completely.
    3. Unscrew the two bolts holding the lever assembly to the floor.
    4. Lift the assembly out. Reverse the procedure to install the new assembly and adjust the cable nut back to the position it was originally.
    You should probably carry out a proper adjustment of your handbrake at the rear wheels before completing the adjustment at the handbrake.
    VY Berlina
    Jun 2010
    Thanks for the instuctions Calaber...I do appriciate it.
    I gave it a shot, but when it came to removing the wire for the handbrake sensor, I felt like i was applying too much pressure and didn't want to brake it. So it's going to the mechanic next Friday to have it installed and get it adjusted properly. Need to have my front struts checked out anyway so thought they may as well do it while theyre at it.
    Cheers anyway, im sure it'll help people in the future too.
    My Ride
  1. Handbrake lever won't sit flush
    By Mark - VE Sportswagon in forum General
    Last Post: 04-10-2010, 09:19 PM
  2. VS Interior Question (Handbrake lever & Auto gear shift knob)
    By RainArcher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2010, 10:02 AM
  3. The Handbrake lever
    By vzlumina in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-12-2009, 07:23 PM
  4. Handbrake Lever + Shifter
    By Josheh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2009, 05:29 PM
  5. Handbrake lever
    By FCCOOL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-01-2008, 05:01 PM
