Results 1 to 3 of 3
Thread: Stock wiring into new battery terminals
    VY S/II S Pack
    Apr 2011
    Default Stock wiring into new battery terminals
    Hey guys,
    So I've done a search and didn't find much.
    Basically I'm buying a new battery soon (probably an Optima D34) and I've got some new terminals on the way like this: Positive and Negative.
    Both have 0 gauge, 4 gauge and 2x 8gauge inputs. On the positive 0 gauge input is a fuse, so that will be used for the amp wire to the boot.
    The question is, how have others gone about connecting the stock power wires to aftermarket terminals that have specific wire size inputs?
    I am thinking about crimping/soldering the correct size wire onto the stock wires for a neat, tight finish, but I would like to hear what others have done.
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    i used like a 0 gauge reducer into the 4 gauge on the terminal which will fit a few wires or like a 4 gauge into the 8 gauge on the terminal
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    What's wrong with factory terminals? Also you may find some of those batteries have 2 sets of terminals. Your regular two posts and then 2 bolts. Connect it to the bolts using O terminals = problem solved?
  1. Battery Terminals
    By jpb308 in forum Electrical Wiring / Questions
    Last Post: 21-12-2009, 08:36 PM
  2. Battery Terminals
    By Deutscher in forum Car Audio
    Last Post: 21-05-2009, 06:28 PM
  3. battery terminals
    By bradcad in forum Electrical Wiring / Questions
    Last Post: 01-10-2006, 03:13 PM
  4. battery terminals
    By R Photon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2006, 07:37 AM
