Results 1 to 21 of 21
Thread: SRS AIRBAG ERROR !!! help
    vy executive s2
    Jul 2008
    Default SRS AIRBAG ERROR !!! help
    Ok so I got new leather interior an when I've put it in an started the car it's come with this
    Now these seats are the same pretty much as my old exec ones accept
    There is this additional plug coming from the seat that wasn't on my exec seats it only had the yellow one which you can see plugged in. It's the same on the passenger side.
    Any advice on what could be causing this or what I can do to fix the issue ??
    CAM'S VY PHREDDIFIED AND LEATHERED!
    http://forums.justcommodores.com.au/...w-leather.html
    Black VY
    Mar 2009
    MELBOURNE
    were all the plugs in properly before you tried starting the car?
    the only way to remove srs warning now is by someone with a tech 2
    vy executive s2
    Jul 2008
    Quote Originally Posted by rx2_freak View Post
    Yea they were all plugged in.
    I had sorta assumed that might be the case
    vx equipe s2
    Nov 2010
    queensland
    same happend to mine when i took my seats out when i done my install, although i have no idea what the second plug is for.
    did you have your battery disconnected when these plugs were off? if not thats why the warning is coming up.
    take your car to holden and they will reset it for $77
    vy executive s2
    Jul 2008
    Quote Originally Posted by hazz View Post
    No I didn't have the battery disconnected ... That makes sense. Thanks for that mate had me worried.
    I'll call Holden during the week.
    vx equipe s2
    Nov 2010
    queensland
    vy executive s2
    Jul 2008
    So called Holden today. As soon as I said I removed the seats he said you got an srs error? So I'm guessing couple people have done the same thing. Got it booked in for ekka show day an only costing me $60 so lesson learnt
    Oct 2004
    Yellow Plug is the pretensioner and the Orange is the Air Bag in the Seat
    If you remove the seat make sure you don't turn your car on while anything with a Yellow connection is unplugged or it will chuck a Mental, You can also Avoid Airbag faults in the future by removing the Airbag fuse under the steering Column No power will get to the SRS Module so it wont know to set the alert off, then when your done put the fuse back in
    Now that its gone off tho youll need to use Tech 2 to reset it
    vy executive s2
    Jul 2008
    vy executive s2
    Jul 2008
    so dropped it into holden today, they cleared the fault, started the car and the fault has come back.
    i have been informed that it will cost upwards of $250 for them to find the fault as they have to remove the seats and check no wires have been pinched or broken during the swap over.
    looks like im taking the seats out again and looking for the fault myself. but will still cost me another $60 to have them remove the code. FML
    vl
    Apr 2011
    brisbane
    if your in brisbane mate, i have a hannatech scanner and will do it cheaper and tell you what code is coming up and can show you all the current data
    vy executive s2
    Jul 2008
    VE Berlina V6
    Mar 2008
    Wollongong NSW 2526
    Happened to a mate of mine...didn't realize the pretensioners had gone off as the seats came from a car thatd been in an accident! Just a thought!
    vy executive s2
    Jul 2008
    Yea that's a concern because I was told that the dash airbags deployed on the car I took these out off.
  15. #15
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Did the seat you fitted come from a VY or a VZ?
    I fitted Calais leather seats to my VY2 Berlina a few years back and they didn't have that single yellow connection - they came with an orange one and a yellow one, both of which plugged into my existing loom. Maybe those seats are from a VZ?
    On another note, I had an error message cleared at my local Ultratune for nix. Even if they charge you, they won't cost anything like the Holden dealer. I doubt you have a pinched wire - I would imagine that mystery plug is the problem.
  16. #16
    vy executive s2
    Jul 2008
    This is what holdens report said
    "clear airbag light
    Unable to clear codes
    Attempted to clear codes failed
    Checked data display an found 99ohms on pretensioner circuits checked"
  17. #17
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    if the airbags had gone off then it sounds like they have gone off also as said above...
    the side airbags only go off in a side impact.
  18. #18
    vy executive s2
    Jul 2008
    So does anyone know what a pretensioner is an if it can be replaced an the cost involved in that??
  19. #19
    Black VY
    Mar 2009
    MELBOURNE
    yeah pretensioners can be replaced[only one bolt holds them on]. they are not cheap though, do you still have your old seats you could just grab them off that.
    http://www.ebay.com.au/itm/Commodore...#ht_2171wt_953
  20. #20
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    i put ss ute seats in my wagon yesterday and i just swapped the whole rails over. its only 4 nuts and they come off.
    if i was you,id just swap the whole lot from your old seats if you can...
  21. #21
    vy executive s2
    Jul 2008
    After a chat with Phreddy this is where we ended up as the cause. I do still have the old ones luckily I hadn't sold them yet. I will be swapping them over in the coming days.
    Big thanks to everyone on this site and special mention to Greg / Phreddy for all your help with this matter as it's has saved me a great deal off $$$$
  1. [VR-VS] How to put an SRS Airbag steering wheel centre on your non airbag car
    By HamaTime™ in forum Holden Commodore How-To's
    Last Post: 18-06-2010, 10:48 PM
  2. vx berlina traction and engine light come on intermittently/// error code error wtf
    By glennis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2010, 07:55 PM
  3. seatbelt airbag error
    By Dan_VX_Spac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-01-2009, 03:45 PM
  4. will disconnecting battery prevent airbag error code being sent
    By muso in forum Electrical Wiring / Questions
    Last Post: 18-09-2005, 07:28 PM
