Results 1 to 3 of 3
Thread: boot light cover
    Nic92's Avatar
    Nic92 is offline Rough As
    2002 VYS S1
    Mar 2011
    WA
    Default boot light cover
    is there a special way to take the boot light plastic cover off without breaking it or do you simply get a flat screw drive and lift it up or something ??
    HoldenOnn's Avatar
    HoldenOnn is offline Roll Cage Territory
    VZ Calais Alloytec190
    May 2009
    Busselton, WA
    Exactly as you said. Get the smallest flat blad screwdriver you can find and lift up one end and then you will be able to use your fingers to pull lens fully out.
    I would recommend removing the interior light fuse first, as its very easy to short the fuse if you touch the boot light contacts onto the metal body when removing.
    Interior light fuse is located under the steering wheel.
    Nic92's Avatar
    2002 VYS S1
    Mar 2011
    WA
    yeah im doing it when my battery is out whe i change my head lights and stuff, thanks for that
  1. [VIC] WTB: VS SS boot lid/garnish + VS Passenger Air Bag Cover
    By nathanVY in forum Swap / Wanted to Buy / Trade
    Last Post: 03-05-2010, 09:42 AM
  2. [VIC] WTB T5 clutch fork cover, floor plate boot etc...
    By Vlad01 in forum Swap / Wanted to Buy / Trade
    Last Post: 27-02-2010, 06:01 PM
  3. FS: Holden Statesman/Caprice Inner Boot Cover
    By CHEFAI in forum Parts And Other Items For Sale
    Last Post: 22-03-2008, 11:58 AM
  4. boot light stays on when boot is closed
    By seans VL Calais in forum Electrical Wiring / Questions
    Last Post: 25-09-2007, 05:17 PM
