My Speedo is playing up these days and went to mech and he told me I need a new speedo, quoted me $600 and will set the kms same as on my old one, but i thought was bit steep,
So went to wreckers yesterdsy and they are giving me one for $150 with few thousand ks above the current one.
So my question is , as my car being a factory Dual fuel , will the second hand speedo cluster work fine in my car ,as the small Lcd in my current speedo shows that when the car is on Lpg or petrol plus the fuel guage works for both fuels.
and also do i need to update vic roads as i am getting a new speedo or not..........?
Can i get any opinions....
couldn't say for sure, but you might be able to use parts from new one to repair the old one so you're covered both way's with your lpg needs.
Worth a try
I would very much doubt they use different clusters.
The lcds are dot matrix so can display anything.
No you don't need to tell vicroads about the cluster, i changed mine for one with lower km's
is the cluster from the same model/spec of car?
