Hi guys,
Just wondering if anyone knows how to bypass the BCM for power windows? I heard there was a thread on Street commodores but cant find itOr is the bypass just for the vt, vx's? ...
Ive replaced all the body wiring to support the regulators but when i hook it up (fuse and relay also inserted) nothing happens... is it because my bcm is a low model? If so is it hard to replace the bcm? or is it just plug and play?
Any help would be greatdon't really wanna update my BCM
I thought it was all controlled from the switch on the VY, I would suggest grabbing Test Light or a Multimeter and probing the front door wiring at the switch and then seeing if you get a similar result out of the rear switch wires ( im talking about the centre console switch by the way not the doors
Do you have the rear door switches hooked up, alot of models wont run unless you have everything connected up
I have all connected but the rears, will connect them Wednesday and let you know
Your just full of info aren't ya mate haha
Haha, just pulled way to many cars apart :X
