I got a vy executive and was getting the Berlina Leather seats with door panel, I think its gonna be a easy swap but the only question arises is of the rear door panel , as i got manual window at rear , so what do you guys reckon , can the trim be modified to fix the handle or do i need to convert the window to a Power Window , if so , is this hard or not.
Thanks alot
Are the rear door panels any different other than the door trim insert and the lack of a manual window handle?
If not just take the door trim card out of the stock trim and replace with the leather berlina card.
Too easy mate, glad I could help![]()
Just a note if you take the front seats out for any reason make sure you disconnect the battery before you touch the front seats otherwise you'll get a SRS warning an you'll have to take it to Holden.
CAM'S VY PHREDDIFIED AND LEATHERED!
http://forums.justcommodores.com.au/...w-leather.html
