Results 1 to 7 of 7
Thread: Locating the BCM
    vy executive s2
    Jul 2008
    Default Locating the BCM
    Ok so I need to locate the BCM in my car I've been told it's near the fuse box under the steering wheel anybody be able to point me in a more accurate direction ?
    CAM'S VY PHREDDIFIED AND LEATHERED!
    http://forums.justcommodores.com.au/...w-leather.html
    MEESEN's Avatar
    MEESEN is offline V8 6 Speed coming :D
    '03 VY
    Jun 2010
    under the steering wheel you'll see a plastic plate above where your feet usually are, there are 2 scrivet like things that pop out with a flat head screwdriver, and a plastic nut in the far left corner... remove them and the plate will drop and to the right you'll see the bcm with heaps of wires running to it
    Hope that helps
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    After you remove the cover referred to above, look above the accellerator pedal and you will see a grey box. It's held in place by two clips at the top and another one of those damned scrivets at the front. It's easier to cut the scrivet away than to try pulling it out. Lower the BCM and you have a couple of multi-pin connectors to release.
    vy executive s2
    Jul 2008
    vy executive s2
    Jul 2008
    Thanks guys found it but needed a mirror an torch to find the serial number.
    MEESEN's Avatar
    '03 VY
    Jun 2010
    vy executive s2
    Jul 2008
    Broke the clips on fuse cover FML
  1. Help needed locating bcm
    By programer in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-07-2010, 02:23 PM
  2. Locating the ECU?
    By Tuff-VP-Wagzz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2010, 12:54 PM
  3. Locating the EFI or DFI Module in a 96 VS
    By FstStig in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2008, 08:46 PM
  4. Locating Air Filter on VS II
    By leasam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2007, 01:49 PM
  5. Help needed locating mudflaps
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-04-2005, 10:26 PM
