Results 1 to 9 of 9
Thread: Vy ss oil warning issue.
    vy ss ute
    Aug 2011
    Default Vy ss oil warning issue.
    hi, I have a vy ss ute and the "check engine oil" alert is coming up on the instrument cluster intermittently. The car has the correct amount of oil in the engine and is not leaking anywhere. There is no oil in the water and no water in the oil. Can someone please shed some light on this? Thanks heaps.
    '04 VY II Calais
    Oct 2010
    Bayside, Victoria
    I've heard that oil pressure sensors are commonly faulty on LS1's. I'd say start there. Someone correct me if I'm wrong?
    03 VY ss hothouse green
    Jun 2011
    hobart
    i won't correct you.
    they are a common thing to go i had mine go but still had oil pressure but i would still fix it. a mate of mine had his go found out it was that and decided he would live with it and about 2 months later he got crap in his pickup and had no warning cause he left it long story short he,s driving a camira at the moment.
    carless for now
    Feb 2007
    perth,Western Australia
    the engine warning light usually comes on if its the oil pressure sensor so you might wanna take it to a mech asap
    vy ss ute
    Aug 2011
    VY II SS Ute
    Dec 2008
    How did you go? Mine has started doing this recently and was told by local Holden dealer it might be oil pump and they could charge me 2K to 'take a look'
    RiCeY's Avatar
    RiCeY is offline F O R U M W A R R I O R
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    2k to screw an oil pressure guage in place of the filter? Tell them theyre dreaming.
    Silver Certified.
    VY II SS Ute
    Dec 2008
    In all honesty I have given up on Holden servicing after they have taken 14 attempts to fix my O2 sensor dramas with still no luck (luckilly thats under warranty). Yea pretty much he said we can check out your oil pump but that involves taking the sump off and labor alone could get close to the 2K mark.
    RiCeY's Avatar
    VZ SV8 6spd 5.7
    Mar 2005
    Australia
    A simple oil pressure test is all thats needed THEN if its low you would start looking at the pump. 2k to look at the pump is a joke it would cost less to replace it including parts.
    Silver Certified.
  1. ANOTHER engine warning light issue. a bit different to others here
    By slowandlow in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2011, 02:32 PM
  2. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
