Results 1 to 5 of 5
Thread: Instument cluster
    VS Berlina
    Nov 2009
    Cool Instument cluster
    Does anyone know how to remove the needles off an instument cluster??
    TazzI's Avatar
    TazzI is offline F*** SpeedHumps
    VY Acclaim
    May 2011
    W.A
    Too easy mate, Just have to lift the needles straight up.
    Iv found the easiest way is using to spoons either side of the dial and slowly lifting up.
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Make sure you mark where to put them back on so they stay accurate
    A Commodore is a passion. Anything else is just a car
    03 VY V6 S2
    Oct 2005
    TazzI's Avatar
    VY Acclaim
    May 2011
    W.A
    If you dont want to mark your speedo template, you can always recalibrate it by holding mode and set and turning the ignition on, keep pressing mode till you get a mode that is a constant beep and the dials move up.
    The dials should all be half way if calibrated correctly, hence temp should be half, rev should be 3000, speedo at 100, fuel at half.
    If it isnt, take note if they are before or past half way, turn car off then move the dial carefully back or forward according to what you need, then repeat!
  1. Little help please vs instument cluster wiring
    By jayrad in forum Electrical Wiring / Questions
    Last Post: 13-01-2011, 11:08 PM
  2. Vh instument cluster
    By Ruskiez in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 10-06-2010, 09:46 PM
  3. Instument cluster changeability.
    By 3206peter in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-04-2010, 09:15 AM
  4. Statesman instument cluster into my vs?
    By Demonica in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2010, 10:01 PM
  5. V8 instument cluster
    By rodge26 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2005, 04:50 PM
