Results 1 to 11 of 11
Like Tree3Likes
  • 1 Post By VYSS_Black
  • 2 Post By TMM
Thread: Best Speed Ranges to Flat-Foot a Stock VY SS Automatic ?
    VY SS
    Jul 2011
    Melbourne VIC
    Default Best Speed Ranges to Flat-Foot a Stock VY SS Automatic ?
    I'm just curious as to what the speed ranges are when the car will actually kick back and rev right out with some pulling power on the stock VY SS's?
    I know for a fact 80k's has a good performance kick if it is flat footed, while on the other hand anywhere between 50-70 it behaves pretty poorly if the pedal is pushed all the way. Sort of behaves as if your flat footing a 92 Honda accord...
    Anybody know the speed ranges where an auto will actually deliver speed?? I know there is another range down low but for me it seems to vary - i think it is somewhere between 10-30 it performs extremely well if flat footed but i want to know the exact speed..
    aaronevolution's Avatar
    aaronevolution is offline Donating Member
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    Not sure about LS1, but L76/L98 don't get peak power until about 5800 rpm, where as torque comes at about 4200 rpm, which is when you can really feel it pull.
    Look up peak torque figures for your model.
    VY SS
    Jul 2011
    Melbourne VIC
    Quote Originally Posted by aaronevolution View Post
    How do I do that?
    TURISMO VZ SS 6.0
    Mar 2011
    Hastings, Victoria
    VY SS
    Jul 2011
    Melbourne VIC
    All I got from that was the following: Torque 465Nm @ 4400-4400rpm
    Dosent really tell me much.. What i am talking about is for instance in my Auto, if i was to flat foot the pedal while doing about 50Km/h, the car wont really deliver much performance at all. Feels almost like driving a 4Cyl Camry.
    But if i do the same around 30-40 Km/h the car seems to deliver performance real well.
    Second best would be from standing still.
    There is also decent performance while doing 80Km/h.
    I have discovered this myself over time.
    TMM's Avatar
    TMM
    TMM is offline OEM+
    VY Berlina S2
    Jun 2008
    VIC
    Quote Originally Posted by VYSS_Black View Post
    Yes it does. If you want a kick then it needs to be at ~4000rpm+
    1st goes to ~60kmh @ 6000rpm. It will only drop to 1st if you are going slower than ~45kmh
    2nd goes to ~125kmh @ 6000rpm. It will drop to 2nd if you are going between ~45kmh ~95kmh
    That's from my V6, but since the V8 has the same gearbox and diff the calculations will still work out.
    If you floor it at 40km/h it will shift to 1st gear and rev from ~4000rpm (40kmh / 60kmh x 6000rpm) to the redline. So you are pretty much in the peak torque band and it'll have a kick.
    If you floor it at 60km/h it will shift to 2nd gear and rev from ~2900rpm (60kmh / 125kmh x 6000rpm), and hence it lacks a kick..
    If you floor it at 80km/h it will shift to 2nd gear and rev from ~3850rpm (80kmh / 125kmh x 6000rpm).
    VY ute (2003)
    Jun 2010
    Manly
    '12 Px ranger 4x4
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    VY 3.8L Executive with Clubby Kit. Ex Marked Cop C
    Mar 2011
    Auckland, New Zealand
    Quote Originally Posted by drift-it View Post
    I found if you manually change to 1st you can kickback at 55ish.
    That doesn't sound healthy, but noted
    VY SS
    Jul 2011
    Melbourne VIC
    Quote Originally Posted by TMM View Post
    Nicely explained - makes perfect sense now.
    VY SS UTE
    Jun 2009
    Mandurah, WA
    Quote Originally Posted by Antsmash View Post
    Yeh thats how you destroy your auto box
  1. How to check Speed sensor is working through the BCM on automatic VR 1993
    By commvr93 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-02-2010, 01:16 PM
  2. HELP PLEASE 4 speed automatic GM 4L60E Manual?
    By wrxstippp in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2009, 09:11 PM
  3. [Ecotec] Not as much power when flat foot as apposed to three quarters of the way down.
    By TI3VOM in forum V6 Development And Modification
    Last Post: 23-12-2009, 10:10 AM
  4. VP 5 speed revs with foot on clutch
    By LS1 James in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2008, 08:34 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
