Page 1 of 2 12 LastLast
Results 1 to 25 of 31
Like Tree4Likes
Thread: What is this sludge......
    vy commodore executive S2
    Jan 2011
    Default What is this sludge.....PICS incl
    I happened to pop my radiator cap as a regular check for water level and found this sludge in there and then same in the coolant dipstick.....
    After going thru the threads it looks like oil in the radiator...but what you guys think from the color ....?
    Is this from the head gaskit or from the manifold ....
    I hope its not too big ...
    are there anyways i can diagnose with it ,before the mech open the whole block to find out...
    Like from the colour....its light brown in the radiator but brown in the coolant dipstick
    The car runs perfect ... I do 100ks every day from my home to job and the temp doesnt go up....Attachment 122672Attachment 122673Attachment 122674
    VY S Series 2
    May 2010
    i had something simliar that was one of the grease pellets holden put in the system... was a bit more white i think though
    Jan 2011
    Quote Originally Posted by Dr HaxZaw View Post
    grease pellets
    Hmmm,,, .....?
    What do u mean by that.
    and Do ypu reckon should i get all the stuff flushed and fill up with new before i take it to mech....
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by Mohi View Post
    Hmmm,,, .....?
    Holden put these pellet things in with the coolant and that suposed to help lubricate the water pump and stop corrosion i think, and yes id flush all the crap out and re fill it with all brand new water and coolant and see if it comes back again
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    If you're taking it to the mechanic, then leave it as it is so he can see it for himself. Also, to check the head and manifold and do any work on them you may lose coolant, so it would be a waste replacing it now IMO.
    Jan 2011
    Hmm,,.... I hope its those grease pallets.....
    Will try to get a comprassion test for the gaskit ....tommorow
    Anything you guys think , i should also look for ....
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Is there any milky substance in the oil?
    Jan 2011
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    mine looked pretty similar when my lim gaskets were leaking. wasnt quite as bad but very similar.. was un noticeable driving, idling, and only lost a tiny bit of water..
    plus they're ppretty common to leak as well..
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    Jan 2011
    Quote Originally Posted by VYMAD View Post
    The engine oil look clean (golden) ...Attachment 122676Attachment 122677
    Jan 2011
    Quote Originally Posted by wana s' charge stock vt View Post
    So was that a expensive fix or not.... how much coin u had to shed to get it fixed
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Well that's a good sign, it may not be your head/head gasket.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    How old is that oil? looks brand new! lol very nice indeed, thats a good sign
    Jan 2011
    Car was serviced around 600ks ago.... got booked in for thursday ,for the inspection
  15. #15
    Sep 2009
    goldcoast
    mace sells the metal lim gaskets for $110 i think but changed it myself. they shit all over the stock plastic'y ones and are re useable...
    and its pretty simple to change(depending). have a search on here for a 'how to thread' and see whats involved in changing it first.
    also there's prob other pic's of sludge like yours no doubt on 'leaking lim' threads.
  16. #16
    Jan 2011
  17. #17
    Jan 2011
    After going thru all the forums, i did the bubble test, where you start the cold engine with the radiator lid open and let the engine heat up, after running for like 15 mins , i went to check it i saw water from the radiator overflowed , but now was still ,, there was no bubbling ,but when i reved the engine only a huge boil of water came but was only one... and then it also settled but there was no bubbling atall......
    and i also tried to drop a big of engine oil from the Dip stick on to the hot engine surface but there was no steam only black somke burnt..so i think there is no water in the engine oil...
    I hope it makes sense ...
  18. #18
    VYMAD's Avatar
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    No, I don't reckon there is coolant in your engine oil, the pic you posted showed good, clean oil with no sign of water therein, as Wogboyz also said.
    Might be an idea to remove your oil filler cap and examine its underside, also run your finger in and feel the inside of the rocker cover, though I would say it will be fine.
    Another possibility, in addition to those already mentioned is that the transmission fluid cooling line may have ruptured inside the radiator. Just a tiny pinhole could be gradually letting fluid into your cooling system. I'm not sure, but if the coolant pressure is great enough when it's at running temp, then it's POSSIBLE that coolant could be in your transmission fluid as well. Have you checked that?
  19. #19
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Im Going to say its the inlet manifold gaskets, i had the same issue with the old VR. replaced Gaskets, flush and refill, perfect for over a year now
  20. #20
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    oh ok, explains the very clean oil lol
  21. #21
    Jan 2011
    Thats what i just did now,, the engine oil filler cap is pretty clean and the rockers aswell...
    then i checked the Tranny oil...it was pretty clean and red ..as you can see on the paper napkin and on my finger...Attachment 122744Attachment 122745Attachment 122742Attachment 122743
  22. #22
    Jan 2011
  23. #23
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    All that is is the pellets that Holden recommend putting in when you change your coolant! The sludge is a slight pinky brown colour isn't it?
    It's there for better cooling.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
  24. #24
    Jan 2011
    At LAST all fixed........
    By true thanks to all of you guys ....you guys saved me from paying $3000 to the F#@kin Midas Greensbrough mech who almost convinced me that my head gaskit was the reason for all the slude...
    but after all your replies and reading thru the different forums i wasnt convinced that it was my head gaskit ..
    so after visitong few Mech around I had it fixed from Auto Volante Auto in Thomastown...
    Midas guy (Tristin) said it was $2000 to fix the headgaskit and them $400 extra for better valves as my car is on Lpg ,and all together fitted back was around$2700 and they keep my car for rnd 1week...
    He said he did the test and found exhaust gases in the cylinder but my car wasnt heating and there was none water in Engine and Tranny oil and he diagonised this all in 10mins and i didnt even see him taking the plastic engine cover off (not sure we have to take this off for the test or not) ..but in the end thanks all of you as you guys replied to all my question with Pics and stuff..............
  25. #25
    s/charged v6 HR Holden, s/charged v6 EH Holden,
    Sep 2007
    My VY Supercharged has the same sludge , its had it for 4 years I have owned it , theres nothing wrong at all , its just like they say , coolant sludge residue mixed with rust from the engine block, I replaced the radiator & coolant about 12 months ago & it still produces this residue , I just wipe it off the cap/ dipstick each time I check the water level. No worries relax go spend your $2800 you just saved on a holiday!!!!
  1. VZ with sludge - best process to remove?
    By SteveBones in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-05-2011, 09:55 PM
  2. SLUDGE bucket
    By thephilth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2010, 03:43 PM
  3. Oil sludge
    By 94SVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2006, 05:32 PM
  4. Sludge Buildup
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-06-2005, 10:26 PM
  5. Sludge Buildup
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2004, 10:30 AM
Tags for this Thread
