Results 1 to 9 of 9
Thread: vy rotors
    '95 vr executive wagon
    May 2009
    Launnie
    Default vy rotors
    need to change the front brake pads on my vy, got standard rotors. was just wondering if i need them machined or not,they only have a slight lip on them.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    How many km on them? Its best to measure. Do you have a workshop manual for the car? Someone on here would. If you have vernier calipers, you can measure the rotor thickness and see if they need replacing or not.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    May 2009
    Launnie
    yer got the manual but not the vernier calipers, i bought it about 12,000k's ago so unsure aobut how long before that they had been done
    Dec 2009
    If the rotors are not undersize and scored then just change the pads. If they are scored you can probably get new ones for about the same cost as machining the ones on your car.
    May 2009
    Launnie
    Dec 2009
    the only thing you have to ensure is the hub surface is clean of any rust, scale or dirt which will cause the new rotor to run out. Best way to ensure this is to get a battery drill with a wire wheel and clean up the hub surface until it is nice and shinny.
    02 VY SS
    Apr 2010
    mmmmmmm what wortus said cause i didnt do that properly and then had to get new ones machined lesson learned
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I just changed all of my pads. My rotors (factory) had a small lip as well. Seem to work great, I'd leave em and chuck new pads on.
    VY Series II Adventra LX8/Captiva CX TD4
    Sep 2011
    Rowville
    I ended up replaceing my front rotors today and so far I am rapped, no more shudder when braking at 100k's!
  1. RDA disc rotors vs DBA rotors
    By Aus78Formula in forum General
    Last Post: 22-11-2011, 09:05 PM
  2. Big Rotors
    By King_berald in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-07-2010, 09:50 PM
  3. [QLD] (FS) DBA GOLD Slotted/Drilled Front Rotors & Rear Standard Rotors
    By markc3012 in forum Parts And Other Items For Sale
    Last Post: 26-09-2009, 10:44 AM
  4. Rotors
    By Ryaz11 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2009, 11:51 AM
  5. Replies: 20
    Last Post: 15-01-2008, 01:42 PM
