I was trying to put a front swaybar in and its bloody hard. So i was trying to get enough clearance between the Kframe and the chassis, in my haste i put a jack under the lower radiator support and jacked it up a bit. Then realised it wasnt actually doing anything other than bending it
So its got a bit of a curve in it now and is about 1cm higher in the middle. the radiator hasnt moved or been damaged but theres a big dent underneath it.
Do you rekon id need to do anything about it? I cant see it unless in looking at it. Is it possible to replace myself?
Im a bit worried...
dont worry mate it wont cause you car to do any think strange and it it is not a load bearing structure
Thanks, good to know, dosent look too bad the next day
I might try and pull the dent out somehow, because the plastic thing underneath dosent clip in in one spot...
