Results 1 to 4 of 4
Thread: 69mm Throttle body any good...
    vy commodore executive S2
    Jan 2011
    Default 69mm Throttle body any good...
    hi
    I got a vy v6 3.8 DUAL FUEL with none mods except for a 2/12 exhaust , i am thinking of getting a bigger 69mm throttle body from MACE Eng ,
    So the question is are there any disadvantages of going for a bigger throttle body in short and long term over the engine..and also apart from a responsive throttle response what else can i expect .
    Power goes up or stays same ..?
    Fuel efficiency goes up , down or stays same....?
    As i have read many people doing the upgrades but haven read any reviews about them..
    Vy ss s2
    Nov 2010
    Townsville Queensland
    Yer mate heaps better throttle response. No negative side effects that I've noticed. I've had one on my vt for 2 years and if you keep it clean it's heaps better than standard. I found I got better fuel economy from it. Hope this helps. You might also want to take a look at plenum spacers from mace. All worth the dollars spent.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    what type of lpg system do you have if you have a standard draw through system you may not see as big as responce as if you had vapor injection
    2003 VY II S-Pack 25th Anniversary
    Feb 2010
    Central Victoria
    i found it somewhat better than the standard one, however i probably wouldn't go spending all the money i did on it if i had my time again.. Monies better spent elsewhere really for more grunt, I found it a tad more awkward to move the car slowly with it, as when i slightly pressed the pedal the car tended to kind of shoot off.. But its not really a big problem
  1. 69mm throttle body butterfly
    By Blakvsexec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-02-2011, 06:57 PM
  2. after installing 69mm throttle body
    By hoofelmuma in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-07-2010, 02:08 PM
  3. 69mm throttle body
    By fritzy21 in forum Mace Engineering
    Last Post: 26-11-2009, 09:46 AM
  4. [TAS] WTB 69mm vy v6 throttle body
    By psivyv6 in forum Swap / Wanted to Buy / Trade
    Last Post: 10-08-2009, 01:01 PM
Tags for this Thread
