Results 1 to 5 of 5
Thread: longtime since i have been here or asked a question soo... help power windows / fuel
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Cool longtime since i have been here or asked a question soo... help power windows / fuel
    My drivers side window has a habit of not working sometimes, i can here a click, like its a contact issue...it's like 1 day it works and the next it day it does not!
    My dist to empty says 0 and I'm still driving around wtf?? it will change if i pump like 20 bucks in her, but if i put 10 bucks in, it says 0.... yeah i dont have to drive anywhere really so that's why I'm so cheap
    Goon
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    If your fuel level lis so low that it reads zero to empty, you are obviously on your last whiffs of fumes, perhaps 2 or 3 litres left in the tank. 10 bucks worth won't even tickle the gauge, but 20 will. It's quite normal to get so low that it reads zero.
    Regarding the window, the problem is either a dud switch, dud connection in the window motor or faulty BCM. The location of the click you hear will be a clue. If it's in the door, it's the motor. Under the dash - BCM. Console - switch. See if you can localise the clicking you can hear first.
    VY S Series 2
    May 2010
    i'd probably just pull the switch out and clean the 2 brass contacts in there... they get quite dirty after a while and i had that problem with one of mine a while ago
    Also the holden feul gauges arent the most accurate things going (they do the job though) so like calaber said its just cause its got no fuel in it and 10 litres isnt all that much in a 75L tank
    Goon's Avatar
    Feb 2006
    GC. QLD
    Cheers peeps, yeah i suspect my cheap ass fuel fill ups are the problem for the 0. I'll sus out the window today.. i think it could be the BCM by the sounds of things, but then again i gave the ride a major clean out yesterday after a long ass trip through the dirt n outback roads, I'll check those brass connections 4 sure b4 i replace parts.
    Thanks!!
    Goon's Avatar
    Feb 2006
    GC. QLD
    All fixed, just dirty connections. thank god!
  1. power windows question please
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-07-2011, 04:29 PM
  2. QUESTION: Power Windows Switch
    By jhomsie92 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-07-2011, 05:18 PM
  3. power windows question/idea
    By Trayner in forum Electrical Wiring / Questions
    Last Post: 27-11-2008, 10:10 AM
  4. Curious Question bout power windows
    By Cootie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2006, 05:02 PM
